120db Reading True or False
walter duque
walter duque
I have been wondering if this could be a true reading on my SBL Meter. My front towers are rated at 115db, Sub #1=115 db@50hz, Sub #2+105db@50hz. When I max my sytem out the SBL Meter goes over 120 db (closer to 130db), could that be possible? It is in a small room.
Adam
Adam
What are the conditions for the ratings on your speakers/subs? For example, what power input and what distance?
allargon
I hope you're wearing ear plugs or something else at anything 80dB and above to protect your ears.
walter duque
walter duque
This is the only information I have for now, and that's for the towers.
System Design Three way power tower with compound bass loading
Bass/Midrange (2) ea 8" high flux cast wool carbon with 1.75" VC
Dedictated power to bass sect. 400 W per side.
Tweeter (1) ea 1" silk dome
Frequency Response 25 hz - 20 khz
Crossover Electronc at 100 Hz and 3 pole/ 18 db/oct at 1.8 khz
Impedance8 ohms
Sensitivity/Max Power 92 db@ 1 W/1M; 350 WRMS
Dimensions/Wt42"h x 9.5"w x 11" d / 69 lbs ea.
Adam
Adam
Thanks for the specs, Walter. I don't see any mention of a 115dB rating, though. I'm wondering why you'd say that's what they are rated at. It's geared towards answering your question on those specific speakers, but not towards the general question about measuring/achieving higher output from a set of speakers in a room as compared to what a single speaker is capable of producing. I'll leave that up to more knowledgeable people.
3db
3db
If the speaker manufacturers are assuming a max spl rating, is that based in an anoechi chamber? If so, I would guess that room reflections and mutilple drivers maybe able to bring the cumulative SPL louder than whats rated for a single speaker. I'm just guessing though.
walter duque
walter duque
QUOTE=Adam;572022]Thanks for the specs, Walter. I don't see any mention of a 115dB rating, though. I'm wondering why you'd say that's what they are rated at. It's geared towards answering your question on those specific speakers, but not towards the general question about measuring/achieving higher output from a set of speakers in a room as compared to what a single speaker is capable of producing. I'll leave that up to more knowledgeable people.
[/QUOTE]
When I purchased the the dealer said it'll hit 115db. These speakers are rated conservativly. The system is in a small apartment. The 120db and above is with all 7.2 not just the towers and the subs.
The 8.3 Power Tower is our premium self powered "fast response" floor standing speaker system designed to exceed the utmost demands of high end Stereo and Home Theater. Using a dedicated sub bass amplfier for each channel has many advantages that include high current, focused power and enhanced dynamics. Dual high flux,cast 8"Quiet Cone™wool carbon woofers, independently powered by dedicated 400 W sub amplfiers, provide deep and detailed bass response down to 25Hz! Each amplifier has level and low pass controls for precise in room adjustment. A chambered 8" midbass/midrange unit is complemented by dual vent (compound) loading for unequalled mid-bass "speed" and clarity Sonic attributes include enhanced aural cues, superior note to note delineation, precise harmonic balance and effortless presentation. Technical measurements boast reference quality flat response with extremely low distortion, "easy" impedance, clean impulse, and over 110 db of dynamic headroom!
Adam
Adam
Well, if you have multiple sources hitting 115 dB (for example), then yes - your total will be over 115 dB. There's a handy calculator to illustrate this at the link here (there are others, but that one allows up to 10 source inputs).
walter duque
walter duque
Adam
Great link, so it is possible. Thanks
croseiv
croseiv
So how far away from the speakers are you making those measurements? Is this at the listening position?
Warpdrv
Warpdrv
Everything is all dependent on the room....
If I put all my stuff in a closet, I'll hit 130db..... :)
I measured my subs (f112 + TC2000) in my bedroom running full out at almost 130db, my mains couldn't keep up with the output of the subs though.
In my great room I can't get those kind of specs, can't say I'm not trying though.... but its close.
Warpdrv
Warpdrv
This is also the reason if you look into car audio the SPL's are ridiculous... :eek:
G
griffinconst
You had your stereo up to 120db in a small apt.? The neighbors should be out by the end of the month.:eek:
I SAID....THE NEIGHBORS SHOULD BE OUT BY THE END OF THE MONTH.
THE NEIGHBORS SHOU....HELLO.:D:D
jamie2112
Now thats funny...........:D
