12" Sub for people on tight budget 79.00
brian32672
brian32672
This may actually be fairly good for people on a super tight budget. And would more than likely be better than most cheap 8" subs that come in a HTIB (Home Theater In a Box)
79.94 and free shipping... Claims 33hz at 100rms and is 29lbs...
http://www.amazon.com/exec/obidos/tg/detail/-/B0002L596M/qid=1125289941/sr=2-3/ref=pd_bbs_b_2_3/102-1304488-2613735?v=glance&s=electronics
Finish: Black
Number of speakers: 1
Directionality: Monopole
Enclosure materials: Vinyl laminate
Powered: Yes
Removeable speaker grilles: Yes
Speaker drivers: 1
Audio inputs: Speaker-level inputs (left/right), 1 monaural RCA line-level in
Audio outputs: Speaker-level outputs (left/right)
Speaker type: Subwoofer
Transducer type: Cone
Continuously variable crossover: Yes
Frequency response (+/- 3 dB): 33 to 150 Hz, +/- 3 dB
Nominal speaker impedance: 4 ohms
Subwoofer power (RMS): 100 watts RMS
Signal-to-noise ratio: 81 dB, wideband
Video shielded: No
Woofers (diameter): 12-inch down-firing woofer
Auto power-on: Yes (signal-sensing)
Item width: 15.375 inches
Item height: 18 inches (including feet)
Item depth: 16.5 inches
Item weight: 29 pounds
Warranty: 5 years parts and labor
In the box: Subwoofer, 4 feet, and a user's manual with warranty information
EDIT:: I have bolded some key points...
Thank Buckeye for the find...
Rÿche 1
Can this thing possibly sound any good for $80 shipped?
brian32672
brian32672
The question should be, would this sound better than a cheap 8" sub that comes in a Walmart HTIB, and at that point - I would have to say yes. So it should even be a upgrade to a cheap 8" or 10" when the whole system cost under 250.00 for a 5.1 with a receiver..
AverageJoe
AverageJoe
I can't really justify it, but I went ahead and ordered it from Amazon yesterday. I'm very curious about the performance, and it wasn't much money. I'll ask rjbudz to help me with an evaluation if anyone is interested (he's the subwoofer king of the neighborhood). Then it'll go into my wife's craft room.
Pyrrho
Pyrrho
I almost did the same thing. Please let us know when it arrives, and tell us your impressions right away. I am very curious about it. I also thought about ordering the Dayton sub for $100 plus about $25 shipping:
http://www.amazon.com/exec/obidos/tg/detail/-/B0002KRALA/
It is supposed to go down to 25 Hz, and someone who reviewed it at Amazon claims that it really does!
SSGohan434
so any opinion on whats a better buy? The dayton sub or this advent sub? thnx. i need to order by today so a quick reply would be very helpful.
AverageJoe
AverageJoe
I think Brian hit the nail on the head - This is a nice unit to replace a HTIB subwoofer without spending much money. And it looks like Amazon has lowered the price back to $79 shipped.
I've had the Advent for about a week, and it performs well enough that I haven't swapped back to my regular subwoofer yet (That doesn't mean I like it as well - I'm just lazy). fyi: My usual subwoofer is a Pinnacle Digital Sub 600 - (600W with two 12" drivers).
Since I'm rather new here, you should probably take this evaluation with a grain of salt. I'm certainly no expert, and my tastes may make this report a bit questionable to some. For one thing, I like a somewhat subtle low freq. experience - I want to hear it, but I don't want to necessarily feel it. I don't like it to seem like the subwoofer is drowning out any other sounds. That said, I still appreciate the nice effects in explosions, etc. But maybe a bit more subdued than most. That's why I asked rjbudz to review the Advent as well. I think he's more atuned to the typical HT experience. Anyway, here's my very brief review:
This unit is a bit of a lightweight - less than 30 lbs, and not a very substantial feel when you rap on it. But, I liked the assortment of controls and connections. Way more versatile than you find on a low-end subwoofer. I placed the Advent in the corner where my Pinnacle usually resides, and set levels using an RS SPL meter and the Avia disk. Crossover was set at 100Hz. I set the level flat to the other speakers for most of my listening, which put the volume control at about 11 o'clock (but also tried it 3dB hotter when RJ was here). The frequency tests were rather surprising - low end was good down to 26Hz, then rolled off drastically. I was fairly amazed it would go that low. The specs in the manual say 33Hz. There was a "hole" between 80 and 90Hz of about 8dB down. My Pinnacle drops about 3dB in that range, so it could be room accoustics. I didn't try to change the crossover to 80Hz, but I should sometime.
DVD selections were Riddick, U-571, Top Gun, and Pirates of the Caribbean. Riddick and U-571 definately need the +3dB, even for me. Even at that, the distant depth charges in U-571 sounded muffled. In Riddick, the AA guns in the attack scene were not quite sharp enough either. The close-up explosions were good, though. All-in-all, I was pleased with the overall HT performance. My only HTIB comparisons are Onkyo's powered 8" SKW-200, and a pretty weak Pioneer 8" passive unit. The Advent greatly outperformed both. Deeper lows, better SPL's (for those that like that) ;) , but a slight trade off for "punch".
For music, I played some Pink Floyd, Bruce Mitchell, and (If you can believe it) Celine Dion's Titanic theme. Once again it was just a bit boomy, but I actually think it is a better music performer than HT.
Conclusions: Again, keep in mind I'm sort'a a subwoofer minimalist, but I though this unit performed very well - especially at lower volumes. I tried turning it up (to about 3 o'clock, with mains at around 80dB) and it was pretty overpowering, but I rarely listen to anything much higher than 70 - 75dB anyway. It seemed to me like the clarity was much better at about 0 to 3dB above the mains. For the price, I'd replace about any HTIB subwoofer in a heartbeat. I think it's worth at least twice the asking price.
Well I promised to be brief, and instead I blathered on. I'll let RJ fill in the gaps.
AverageJoe
AverageJoe
Oops, maby that should go in the "Review" area. Sorry about that.
Pyrrho
Pyrrho
Often, there can be an increase in the frequency response of a subwoofer due to room gain. In an anechoic chamber, it is likely to be as they say. In fact, your experience would suggest that Advent is honest in their claims.
As far as I am concerned, the more details, the better (within reason). Thanks for your comments.
I am glad you posted it here; I would probably not have seen it if you posted in a different area. Anyway, it is a continuation of the topic at hand, so I don't think anyone has any basis for complaint.
