$10k to spend on home theater need help spending it
mancan
I'm trying to decide on the best quality setup for my circumstances. I like the towers for fronts and l like the double angled speakers for sides but prefer dull black color on the speaker but would consider others like wood. I just don't like the high gloss look or colors that stand out.
I'm looking at doing this soon please give me an unbiased opinion on what you would do
Projector
I'm willing to spend between $2500-$3500 on a projector, I will watch sports and movies equally no gaming. The stereo and speakers is for movies not much high level music listening although we will listen to music via pandora etc. I have total control of lighting in my basement. My room is a big rectangle I have pool tables and other gaming behind the theatre seating. My seating is about 13 feet from the screen so is the projector. I have about 9 foot of ceiling height and dark fire brick painted walls.
Was looking at the epson 5030 and 6030
The panasonic ae 8000
JVC's DLA-X35
Speakers
Was thinking about the following speakers around $4500 total
Klipsch
RF-82 II 5.2 Home Theater System
SYSTEM CONSISTS OF THE FOLLOWING:
(2) RS-52 II Surround Speaker I like the way these speakers are designed angled two sides
(2) RF-82 II Floorstanding Speaker
(2) SW-115 Subwoofer really would like to have two subs
(1) RC-62 II Center Speaker
I'm not locked into the klipsch it's just seems to have high ratings and I assmume they are reputable company that has been around awhile. I looked at golden ear, svs along with definite techs theater systems. I would like to stay with one company that has complete theater systems.
Receiver
Stereo Denon AVR-X4000 AV Receiver $1300 I'm not locked into this either and I don't need other zones. I would like a networking receiver, I think? I would like as much power as possible. F
I'm intrigued by the audyessey multi eq and bass eq
Screen
Da-Lite - 24416 $1700
113" Diag. (60x96) UTB Contour Fixed FrameProjector Screen, HD .6 Fabric, 16:10 Format **** not sure what gain screen I need again for movies total darkness for games there will be some lighting but at least 15 feet from screen controlled lighting.
I need a very small frame I've got exactly 60" of height clearance. Again not locked into this screen. Also While watching games we will have lighting on behind the seats
Remote controls and wiring is a wash not sure the best remote to control but I will 3 direct tv boxes and tv's a blueray and probably apple tv. Roughly looking at $10k budget for the above mentioned without installation, wiring or remotes.
I forgot to mention I will have two 50" plasma tv's on each side of the screen and this is not part of my 10 k budget. I don't think this will effect lighting on the screen will it? They will be within 3 inches of the screen.
GranteedEV
GranteedEV
you can do a LOT better than Klipsch. Look into Revel and KEF.
zhimbo
zhimbo
...and even if you like the Klipsch speakers, don't get hung up on sticking with the same brand for the subs. You do *not* need to stick with one company for the subs - companies that make great speakers don't necessarily make good subs, and vice-versa.
It also sounds like you have a pretty big space to fill, so you're going to need quite a bit of subwoofer output. You may want to tilt the scales towards the sub budget a bit more.
tcarcio
SVS is one of the best you can get for subwoofers and they have deals on buying 2 like this...Dual PB-2000 - SVS Plus they have free shipping and in home trial period which is really nice.
I would stick to Revel, KEF, and RBH. I've also heard great things about Phase Technology and Atlantic Technology.
The Denon X4000 is an excellent choice. You should be able to get it for a lot less than $1300. ;)
Definitely don't pay MSRP for anything whether it is amps or speakers or projectors. :D
