I'm sorry to hear you have a BD player. I meant I'm sorry to hear that you are having problems with your BD player.
My experience with HD tells me flicker comes about because of:
1) incorrect fw upgrades
2) 1080p display at something other than 24Hz.
So the resolution for these two issue would be:
1) ascertain that your firmware is the most appropriate for your setup (not necessarily the latest version)
2) ascertain that your set at 24 Hz (w/ a 24 Hz capable display).
Also, if you post your connections and settings, and whether this only happens with only certain discs (or all discs), that may help elicit more direct responses. Hope that spins the wheels for you. Cheers.
