1080p Blu-ray output from PC?
sploo
Hope this is the right forum...
I'm just about to take my first plunge into HD, and should shortly be getting a 1080p capable plasma TV.
I want to put together a PC to play Blu-ray discs and was about to buy an ATI 3870 based card (http://www.sapphiretech.com/us/products/products_overview.php?gpid=217&grp=3) . However, I noticed that the spec sheet (linked on the right of the page) indicates that the supported HDMI modes from the card are 480p, 720p and 1080i.
I thought that 1080p over HDMI/DVI from a modern gfx card would be pretty standard. Is there something I've misunderstood? Should I be concerned?
G
gus6464
Read my response in the video games section about the video card. Basically don't get the Radeon but I did recommend a better one for around the same price. Also whatever you do go with 4gb of ram for high def content. I assume you will be putting windows vista in the machine? If you do get the 64bit version of whichever one you choose. Nice choice on the Gigabyte P45 btw.
jnmfox
jnmfox
I would recomend jumping up to the ATI/AMD 4850. It is the only currrent card that will do 8-channel LPCM over HDMI.
http://anandtech.com/video/showdoc.aspx?i=3338&p=2
Plus it will be much better at playing games, it has been a long time since you could get this much performance for $200.
http://anandtech.com/video/showdoc.aspx?i=3341
One other option is to invest in a PS3. I considered using my PC for a Blu-Ray player, I used to use my PC for an HD DVR, but wanted the simplicity of the PS3.
sploo
gus6464 - thanks for the reply. I'll respond on the games forum.
jnmfox - thanks for the info. I was considering a PS3, but we've just had some basic HD channels launched on a free satellite service here in the UK. There's not much on it right now, but I'm expecting it to expand. I was planning on getting a suitable DVB card, and using the PC as a DVR as well as a Blu-ray player. Plus if I got a PS3 I'd be tempted to buy games, and I just don't have the time to play 'em :D.
