I see several reasons that this driver will not work very well.
First is the limited frequency response of 80hz-15,000hz which cuts off the upper and lower frequencies.
Second the resistance is 4 ohms, which very few receivers will be happy driving.
Third the max power is only 40 watts. So unless you are using tube amps to drive them (very few made can drive 4 ohms well), then any receiver you use will overpower and possibly blow them.
I would say that a conventional 2 way will be a much better option all arround.
-Greg
