MUDSHARK said:
Which would you prefer for 12 by 14 foot den music system utilizing Infinity Kappa 400 speakers (90 sensitivity 4-6 ohm ) and a budget of 1500-2000 for an integrated amplifier or separates?
.....and MudShark, if you got a used McIntosh Pre-Amp, around the C-28 to C-31 range, to go with the K-Series amp, I assure you, you would have something....your speakers are efficient at 90, I think it was, and others will yell how could you need that many watts?....the Crown K-Series is excellent in ALL areas, I have found....your speakers would only get as loud as you choose, with clarity rare, from K-Series power....and I mean power....unbelievably clean, crisp, and bright......
.....edit....and thanks to WmAx, I'm working toward using the balanced inputs on the K2's I have....I think I'm going to go ahead and order elements for small cannons....and a Behringer 2496....I can swap things around to not have to get more power at this time....like somebody cares.....buncha' Neanderthals.....don't turn around and look.....
