The only advice I have is to return them.
Chipbyrd is a forum member in good standing
I just picked up a pair of these interconnects. I plan to install them tomorrow evening. I have never installed locking ic's. Any advice?
HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
Are you sure which side of the glass you are on?
Rickster71 (07-12-2012)
For the prices they charge I would hope they at least provide instructions, if not KY jelly.
"Knowledge is knowing that a tomato is a fruit; wisdom is knowing not to put it in a fruit salad" - Anonymous
Some of my systems: http://cgi.audioasylum.com/systems/1606.html
I bought them because I heard and read good things about them. I bought the 1.5m for $250. At that price I thought I would give them a whirl. Not a fanboy, just trying something different.
I've tried cables way more expensive than that and found that spending that much really doesn't really get you anything but a lighter wallet. While there may be slight differences in sound, that kind of outlay REALLY isn't justified for what you get. I use Bluejeans ICs and they sound just as good as anything else I've used and for $250 you could have bought 8 or more pairs of them.
Not trying to knock you, just saying that high dollar ICs are one of those things that just make money for the manufacturer without returning real results to the end user. Ultimately, it is one of those places where good is more than good enough and that money can be spend elsewhere where it will make more difference.
Not sure what the purpose of "locking" ICs would be either, since they are a compression fitting already. If one does come loose, it is defective.
