Here we have a nice budget AVR .Yamaha RX-V675 7.2 Channel Network AV Receiver with Airplay.
List Price: $649.95 On Sale Price: $399.95
Key Features
- 7-channel powerful surround sound
105 W per channel (8 ohms, 1 kHz, 0.9% THD, 2 ch driven)
90 W per channel (8 ohms, 20 Hz-20 kHz, 0.09% THD, 2 ch driven)
- HD Audio format decoding: Dolby® TrueHD and DTS-HD Master Audio™;
Dolby Digital Plus and DTS-HD High Resolution Audio™
- Full discrete amp configuration
- Pure Direct for pure Hi-Fi sound quality enjoyment
- Burr-Brown 192 kHz/24-bit DACs for all channels
- Low jitter PLL circuitry helps optimize sound imaging
- Assignable amplifiers for front speaker bi-amp connection
- Intelligent assignable amplifiers for Surround Back, Front Presence or Zone 2
- FLAC or WAV 192 kHz/24-bit audio playback
The RX-V675 from Yamaha – 7.2 Channels of Simply Exceptional Sound
The RX-V675 from Yamaha offers versatile speaker options include 7.2 channel surround, front presence, bi-amp main speakers or independent Zone 2 operation. The Yamaha AV Controller App provides simple yet powerful network control in either zone at once. Installation is a breeze when you use the advanced YPAO™ (R.S.C.) auto calibration and sophisticated graphic user Interface to expedite setup and ensure accuracy. Expand connectivity with MHL® (Mobile High-Definition Link), AirPlay® and music streaming services and versatile USB input for iPad® compatibility. Enjoy ECO mode today and Ultra HD (4K) up-scaling for next generation of super-high resolution displays. The RX-V675 provides refined digital processing for an enriched audio video experience.
Total Purity Concept for the Finest Sound Quality
The Total Purity Concept, which Yamaha has been cultivating for many years, encompasses high drive amp technology, high purity pre-amplification, anti-vibration technology and independent pure power supplies. All models have a fully discrete power amplifier that helps to minimize distortion. They also adopt independent pure power supplies, allowing dedicated power supplies for the analog and digital circuitry to prevent digital noise from affecting analog circuitry. The anti-vibration heatsinks are designed to suppress vibration from transistors and sound pressure. Independent power supplies for the DACs are designed to further eliminate noise on certain models. Down to every detail, these AV receivers are designed with full emphasis on the highest possible sound quality.
Extensive Audio Codec and Format Support
This AV receiver is compatible with many audio formats such as Dolby® TrueHD and DTS-HD Master Audio™. They are also compatible with FLAC/WAV 192 kHz playback. You will enjoy excellent Blu-ray Disc™ sound quality and other types of high resolution sources.
Click here for a larger image
Intelligent Amp Assign
Intelligent Amp Assign automatically assigns amplifier channels to certain speakers depending on what functions are selected. For example, in a 7.1-channel system, when Zone 2 is off, all 7.1 channels will be used in the Main Zone. However, when Zone 2 is on, power to the two surround back channels will be directed to the two speakers in Zone 2 and the Main Zone will receive 5.1 channels of power. Similarly, when CINEMA DSP 3D is on, the two Front Presence speakers will be powered and not the two surround back speakers. When CINEMA DSP 3D is off, this situation is reversed. Thanks to Intelligent Amp Assign, there's no need to switch the speaker cables on the rear of the receiver — one more way Yamaha makes your life a little easier.
Ultra HD (4K) Pass-through and Upscaling Supports Latest High Resolution Video Formats
This AV receiver's HDMI input/output supports Ultra HD (4K) video image pass-through. It also can perform Ultra HD (4K) upscaling to boost a lower resolution image to super high-def resolution. This ensures compatibility with the latest super high resolution video formats.
HDMI® with 3D and Audio Return Channel
3D means the receiver can handle 3D signal data. The Audio Return Channel function enables data to be sent and received via the same HDMI cable so you can hear the sound from the TV via a single HDMI cable with no need for an extra optical cable.
High Quality Video Processing with Edge Adaptive Deinterlacing
In ordinary deinterlacing, pixels in areas of movement are interpolated by upper and lower ranges. This causes jaggies in diagonal lines. Edge adaptive deinterlacing detects the direction of the line and interpolates the pixels optimally.
SCENE for One-touch Start
Pressing a SCENE button powers on the AV receiver and selects the input source and DSP mode. You can reset the buttons for different sources by selecting a source and DSP mode then pressing a SCENE button for more than three seconds.
HDMI CEC for Easy Operation
Another benefit of HDMI is the availability of CEC functionality. When the unit is connected to a CEC compatible TV, it will turn on and off together with the TV and you can use the TV remote to control the volume. CEC also provides advanced functionality with other components. For example, you can use the receiver's remote unit to control player functions like skip and stop.
*All connected devices must be HDMI CEC compatible. Some CEC compatible TVs/players may not work.
AirPlay Allows Streaming Music to AV Receiver
This AV receiver supports AirPlay, which means they can accept wireless music streaming from iPod® touch, iPhone® or iPad®, as well as from iTunes on Macs or PCs. This makes it easy to enjoy music from your mobile devices or computer on your home theater system. You can use view metadata such as song title, artist name as well as album art* via the AV receiver's on-screen display.
*Some models don't support album art display.
AV Controller App for Easy, Convenient Operation
This AV receiver lets you use the Yamaha AV Controller App that is downloadable from the iTunes App Store or Google Play to control power on/off and volume, select input and DSP modes and operate other functions from an iPhone® or Android™ devices. You can also use in as many as 23* different languages and customize the interface by hiding unused icons and renaming functions. A tablet version is also available.
*As of Spring 2013.
Network Functions
This AV receiver provides a variety of network functions that enable you to access more sources and also enhance operation. You can connect the receiver to a PC to enjoy Internet radio, Pandora® and Rhapsody®, and operate your system via WebBrowser Control. The AV Controller App (from iTunes App Store or Google Play) lets you control various functions from your iPod®, iPhone®, iPad® or Android devices.
MHL® (Mobile High-Definition Link) Support for High Quality Video and Audio
MHL provides easy, direct connection of compatible mobile phones and this AV receiver. Playback of up to 1080p video and multi-channel audio from the phone is supported. The receiver also charges the connected phone. Play, Stop and other basic operations can be controlled from the remote control.
USB Digital Connection for iPod, iPhone and iPad on the Front Panel
A USB port on the front panel allows convenient connection of an iPod/iPhone/iPad, which also charges when connected. Because the digital signal from the iPod/iPhone/iPad is transmitted directly to the AV receiver, there is no signal loss or interference, so you enjoy the best possible sound quality. In addition, you can use the receiver's remote control unit to operate the iPod/iPhone/iPad music playback functions.
Advanced Multi-language GUI On-screen Display
Yamaha's latest graphical user interface has a high resolution display with clear, easy-to-use menus and also includes a selectable status bar that shows input source, volume level, DSP mode and audio format. The GUI provides a choice of eight languages: English, French, German, Spanish, Italian, Russian, Japanese and Chinese and can be displayed over both normal and 3D pictures.
YPAO-R.S.C. (Reflected Sound Control) Sound Optimization
YPAO-R.S.C. analyzes room acoustics and measures various speaker characteristics, then calibrates audio parameters to achieve optimum sound. It employs Reflected Sound Control to correct early reflections for studio-quality sound. It also provides DSP Effect Normalization, which varies the CINEMA DSP parameters according to the reflected sounds.
HDMI Front Panel Input
In addition to the large number of HDMI inputs on the rear panel, there is also one on the front panel. This gives you a convenient way to quickly plug in a digital camera or camcorder for highest quality pictures.
Input Selection in HDMI Standby Through Mode
When the AV receiver is in HDMI Standby Through mode, the input source (Blu-ray Disc™ player, game console, etc.) for viewing on the monitor can be changed via the remote control. There's no need to turn on the AV receiver in order to switch sources.
HD Audio with CINEMA DSP 3D and Virtual Presence Speaker
CINEMA DSP 3D provides a wide, high and dense sound field. HD Audio format decoding lets you enjoy HD Audio sources. Virtual Presence Speaker delivers 3-dimensional sound without actual use of presence speakers.
Dialogue Lift and Dialogue Level Adjustment for Natural Dialogue and Vocals
Dialogue Lift raises the sound of dialogue from the center speaker to a position in the center of the screen. Newly developed virtual dialogue lift achieves dialogue lift function even without the need for presence speakers. Dialogue Level Adjustment lets you control the volume of the vocal sound, so you hear movie dialogue and music vocals at the ideal level for clear, comfortable listening.
Adaptive DRC (Dynamic Range Control)
Adaptive DRC automatically adjusts the dynamic range of the sound according to the volume level. This ensures that you hear clear dialogue and vocals and all sound effects at comfortable levels. There is no need to adjust the volume level as you listen; everything from whispers to big explosions will be heard clearly and comfortably at the same volume setting. It also tones down loud TV commercials and is ideal for low-volume, late-night listening when you do not want to disturb others.
New Virtual CINEMA DSP for 7.1-channel Surround Sound
New Virtual CINEMA DSP provides virtual 7.1-channel surround sound from only front speakers (2.1-channel), with no need for rear speakers. Using new 24 kHz HRTF (Head-related Transfer Function) technology, it creates a rear sound field that is extremely spacious, natural and powerful.
Optional Accessories
YWA-10 Wi-Fi Adapter lets you stream music wirelessly via a router from network components such as a PC or NAS.
YBA-11, Bluetooth® Wireless Adapter lets you stream music wirelessly from a Bluetooth-capable smartphone, tablet or PC without a Wi-Fi environment.
Other Notable Advanced Features
- Selectable Auto Power Down
- Supports Deep Color (30/36 bit), x.v.Color, 24 Hz refresh rate and auto lip-sync compensation
- SILENT CINEMA™ and Virtual CINEMA DSP
- Two subwoofer outputs (simultaneous outputs)
- Compressed Music Enhancer
- Subwoofer Trim Control for improved sound imaging
- Eco-friendly design ECO Mode lowers power consumption by 20 Percent (Compared to power consumption when ECO mode is off)
- Low standby power consumption
- Charging of iPod®, iPhone® and iPad® via USB when AV receiver is off
- iPod/iPhone/iPad song titles displayed in English and Western European languages on the front panel
- Audio input assign capability for HDMI and component video input
- Audio delay for adjusting lip-sync (0-500 ms)
- Preset remote unit
- Background video feature (for tuner and network sources)
