World's smallest DAC? Check out M2Tech's hiFace USB DAC
admin
Audioholics Robot
Staff member
Is this the smallest DAC in the world? We think so. The question is, will the quality be worth the $295 cost of entry and do you need more features than a simple stereo analogue output?
Read what else we said about the M2Tech hiFace USB DAC
F
fmw
In order to sell it, they probably need to put it in a 17" wide cabinet with 5 lb. weight in it. ;)
haraldo
haraldo
Review please !!!!!!!
M2tech do also have other very interesting products, like a USB based s/pdif interface, good if you already have a hi-end dac :D
Plasmali
size correction: Metric - (2 x 1.4 x 8.8cm)
just thought I would correct the size in the announcement. It's actually metric at 2cm x 1.4cm x 8.8cm:)
macddmac
macddmac
Looks like audioquest's dragonfly.. Only 50$ more. I'll take a dozen!! Not:D
Audioengine D1 is 130.00 less ,has 2 inputs, and you can adjust volume on the unit. Not much larger either.
Cheers, Mac
