Pogre
Pogre
I have a great-room layout where the kitchen and living room share the same space. it's ~15 x 30' rectangle with another room open on one side, a hallway and vaulted ceilings . Both subs are up by the receiver and main speakers (not quite symmetrical but that's where they sound best right now.). I have about 9 1/2 feet between them, they're close to the front wall and they're about 3 feet from the corners on either side.
I'd like to try putting one in an out of the way corner beside our pantry in the kitchen (or possibly another if that doesn't work) on the opposite side of the room, but I'd need a ridiculously long rca and I don't want to have it running along the floor or anything. I suck at climbing around attics and fishing wires too. A quick search turned up this. I know someone here has some experience with wireless adapters, but I dont see them suggested like, at all. Which leads me to believe it's not a great option. The kitchen is behind the seating area.
I've read some negative things about Rocketfish stuff here and there, but think that was more in use with surround speakers, sub range I think has less issues in general with wireless kits. You might also look at this one, albeit more expensive.
Pogre
Pogre
That's what I'm looking for! Some other suggestions. I've read that Rocketfish stuff can be iffy too. I'm willing to spend a little more for something that won't drop or degrade the signal. Is it just generally not a good idea because the tech isn't there yet? Or can it be done seemlessy with no problems with the right adapter? Will there be any timing issues with wireless being a little slower (one will be wired)?
*Edit: Looks like there are a few on Ebay a little more in my ballpark.
I've got two Infinity subs that came with transmitters and built-in receivers, never had any interference issues; think they used to offer a kit for purchase at one point, too. As far as potential interference I don't have a lot of stuff around that would interfere afaik. Think there's also a brand called Amphony out there...but may be same stuff as Rocketfish. If you buy from Amazon and it doesn't work should be easy enough to return....
Pogre
Pogre
Gotcha. Thanks for pointing me in the right direction. I edited above. Found a couple on ebay, look new, for $70-80.
William Lemmerhirt
William Lemmerhirt
Can't say for sure but I'd be curious about latency too. Probably fix it with phase and avr distance settings etc. I read about the rocket fish ones when they were new, and they seemed to be good. Maybe now that there are more out in the wild, the issues might be more out in the open.
As far as the additional delay involved, never had any particular issue resulting from it...
Pogre
Pogre
That's great to hear. I was afraid one of you vets would come in here and tell me how horrible they work. Does that sound like a better placement scenario with my subs on opposite sides of the room as opposed to having both up front?
Opposite corners can work well but odd rooms can be odd rooms....one way to find out :)
Pogre
Pogre
Gotcha. I'm learning room modes are pretty critical and every one is different. I have more than a couple good candidates for good placement in the kitchen. I can put one right in the corner as just one option. I think with a little more experimenting I can find a much better spot for one of them though. I'll do the sub crawl around the kitchen til I find the best spot, then run Audyssey again.
William Lemmerhirt
William Lemmerhirt
I was thinking more because one would be wired and one would be wireless. Very possible no issues at all. More of a question I guess.
I mixed my two wireless subs with a wired for a while. Bigger issue was they couldn't keep up with the wired sub....they weren't as capable.
William Lemmerhirt
William Lemmerhirt
Well that kinda trumps the wireless thing I guess.
Pogre
Pogre
Omg I'm already seeing I could easily fit 2 more subs without it being a nuisance or an eyesore... *gulp*
