Will this work together?
Cajun Ag
I'm a long ways from an audiophile, and quite frankly it's killing me to spend the money setting up this home theater room when I've had my eye on a lathe and mill for my shop. Here's what I've pieced together from reading through various forums. I would like to know if I will have any issues with these components blending and being on speaking terms with one another.
Sanyo Z5 projector
Yamaha RXV 661 Receiver
Oppo Dv 981 DVD
Non-HD (right now) Direct-TV Sat
SVS Model SCS-01M 5.0 Package Spkrs
BIC H-100 Sub
That all comes to about $3200 w/o any cables, screen, etc. :(
Please feel free to give me some ideas on cutting some costs. I'd like to get this down about $700
Thanks in advance
avaserfi
avaserfi
Everything should work very well together. To get good cheap cables I would recommend going to monoprice.com or bluejeanscables.com. Another place to look for speakers and a sub that would be less expensive would be HSU research. They have packages that are complete 5.1 set-ups and their horn speakers got a good review on this site as did their woofers.
Buckeye_Nut
Sanyo Z5 projector
Oppo Dv 981 DVD
BIC H-100 Sub
Thanks in advance
The Bic sub stands out like a red herring. Since you're already buying from SVS.....get the SVS sub instead. SVS offers superior build quality & performance compared to the former, so you wont have any regrets.
ParadigmDawg
ParadigmDawg
Or you could look at the AV123 packages but I dont know if they are any cheaper than the SVS. I think you have done a good job picking out a pretty inexpensive system that will sound good.
Good point Buckeye; maybe look for a different sub.
jcPanny
jcPanny
HT Gear
Cajun,
Good list of gear for the HT.
I agree on the BIC sub. You should consider one of the SVS packages with their 10" sub. They might still have the White and Silver colors on sale for $800 for a 5.1 system.
For souce material, you might consider an HD-DVD player for comparable cost to the Oppo. The Toshiba HD-A2 is selling for around $250 and will do a good job of upscalling regular DVDs in adition to HD-DVD playback. If you want a regualr DVD player, the Oppo's are great, I have the DV970. For your 720p projector, you could save a few bucks and go with the DV971 model.
Also, don't forget about a screen.
Cajun Ag
Thanks again for the help.
I'm considering just going with the HSU Research Enthusiast 1 Pkg. Can you think of some other areas I may be able to cut costs? 661 Recvr? Any opinions on a good screen. Will need to be pull down or elect and I'll be viewing it from about 12' so what's good size.
no. 5
no. 5
If you want the home theater, but want to spend the money on something you like more, spend it on what you like more.
If you would want a lathe, mill and a home theater, then may I suggest not buying everything for the home theater at once; perhaps starting with a 2.0 system and over time getting a full 5.1 system. And depending on if and what HD sources you may be planing on, you may be able to get along with the RX-V659 rather then the newer RX-V661.
Just a thought. :)
AVRat
AVRat
Depending on your visual tolerance, a 100"-110" +/- dia. screen would be an appropriate starting point.
jcPanny
jcPanny
Av123 Gc
The X-series speakers from AV123 are another good option and their current Gift Certificate promotion will get you an extra 10% off.
With a front projection setup, it is nice to have a single video connection for all sources so the Yamaha RX-V661 w/ HDMI would be convenient.
You could cut costs slightly by initially projecting on to a white wall, getting a cheap pull down screen (DaLite, etc.), or a DIY fixed screen.
mazersteven
mazersteven
Spending money on your HT room is killing you? :eek:
Try playing some Barry White on your Lathe in your Mill for your wife/girlfriend, and see how much Nooky you get. :eek:
That HT room should be looking better, and better when you see it in that light. :D
mazersteven
mazersteven
The SVS system is $875
Look at this
5-x-cs Center/Main/Surround Loudspeaker's = $695
http://www.av123.com/products_product.php?section=speakers&product=91.1
There is $200 saved. Well almost. :D
If I was going to spend $800+ on speakers this is what I would do. JMO
2-x/mtm's $449
1-x/cs center $139
2-x/ls surrounds $219 or 2-x/cs surrounds $278
http://www.av123.com/products_product.php?section=speakers&product=105.1
http://www.av123.com/products_product.php?section=speakers&product=82.1
Might even want to look at the new sub they are offering? Looks interesting.
http://av123forum.com/showthread.php?t=22692
Cajun Ag
mazersteven,
I am married and therefore nooky is unavailable and a non-issue. :D
thanks again for the info.
Davemcc
Davemcc
mazersteven,
All the more reason to hide out in a man-cave with an awesome home theater.
