So I will spell out my HT setup.
Marantz SR7001 (as a preamp)
NAD T955 Power amp
Klipsch KF-28 Icon 8'' mains
Klipsch SF-1 Surrounds
Klipsch SC-1 Center Channel
I have an older Klipsch KSW-12 Synergy series subwoofer from the late 90s, that has served me very well. On this latest BF I managed to snag the Klipsch 12'' Reference Sub R-12SW for about $150 using some store credit.
Should I just ditch the old Synergy, or run a dual sub setup?
Some stats.
New Sub (R-12SW)
FREQUENCY RESPONSE 29Hz-120Hz +/-3dB
MAXIMUM ACOUSTIC OUTPUT 116dB
AMPLIFIER All digital
AMPLIFIER POWER 200W / 400W
DRIVE COMPONENTS 12" (30.5 cm) high excursion, IMG, front-firing woofer
ENCLOSURE MATERIAL MDF
ENCLOSURE TYPE Bass Reflex
INPUTS Line level/LFE RCA jacks
HEIGHT 16" / 40.64 cm (16.5" with feet)
WIDTH 14" / 35.56 cm
DEPTH 18.5" / 47 cm (19.2" with grille)
WEIGHT 33 lbs (15 kg)
FINISH Brushed Black Polymer Veneer
BUILT FROM 2014
FEATURES Volume, Lowpass, Phase, Auto Power
PHASE Switchable 0-180 degrees
Old Sub (KSW-12)
Power handling, FTC Rated Power: 105 watts continuous, 22-100Hz @ ≤ 1% THD
- Power handling, Dynamic Power: 440 watts @ ≤ 1% THD
- Sensitivity: 113dB SPL 1/8 space, 1 meter
- Low pass crossover: Continuously variable from 40-120Hz, 24dB/octave slope above 120Hz
- Woofer: K-1071-K 12” (30.5cm) down-firing fiber-composite cone
- Amplifier: Class A/B discrete MOSFET outputs
- Phase: Switchable 0 or 180 degrees
- Enclosure type: Bass reflex via rear-mounted port
- Inputs: 2) Line level/LFE RCA phono jacks and 2) High level speaker terminals
- Outputs: 2) High level speaker terminals, high pass filtered at 100Hz, 6dB/octave slope
- Auto power on: 2 Second ON delay, 15 minute OFF delay
- Dimensions: 17” (43.18cm) x 15” (38.1cm) x 15” (38.1cm)
- Finishes: Matte-finish Black vinyl
- Voltage: 110/120 VAC/60Hz
- Export voltage: 230 VAC 50/60Hz
- Built from: 1998
My receiver only has one subwoofer output. So I would need to run a Male to dual female Y-Splitter, a cable. Then a single female to two male y splitters (I don't think this part is necessary, as both subs have a LFE input, but I have always run a splitter on my subs.)
