Hello
Here's my WIP 5.1 HT system,
Front Left & Right = Focal Chorus 826V
Center channel = Focal Chorus CC800V
Subwoofer ( planning ) = JL Audio e110
Surround rear ( planning ) = Either Focal Chorus SR700(difficult choice for my room) or Focal Chorus 706(BookShelf).
Do you see any issues with using the mentioned bookshelf speakers for rear surround ?
I was originally planning to get the SR700 surround speakers, as recommended(by manufacturer/dealer), but it poses a problem with my room setup. If I were to mount these on the walls, they'd be placed slightly(by a feet) infront of the listening position (and not 90-110 as desired for rear surround). I have an opening towards the left of my seat, just behind the seat position(Right side wall is long and not an issue). Placing the rear surround slightly infront of the ears is bad, I suppose.
Another option for me is to mount the bookshelf speakers on tall stands behind me. Understand it should be above the ear position. What would be the minimum height of the stands I should be shooting for these ?
Also , should I need to be concerned about placing additional load on the receiver by using a bookshelf than a designated surround speaker ? (or the receiver calibration will take care of it)
Appreciate any advice/thoughts..
Thanks
