Convo
You may not be able to get another in the future unless you can get a used one, that is a discontinued model.
Yea, thanks for that. I did take that into consideration. It just seems like this sub falls somewhere between the PB1000 and the SB2000 so I'm hoping it sounds good enough. Worst case, I upgrade down the line and use this to build a system in my livingroom that is a smaller space. But finding a good used one might be ideal in the future so I can run 2:)
cel4145
cel4145
The SB2000 is the upgraded version of the SB12. So you could always get one of those.
Convo
So I ended up calling SVS about this model and they talked me out of buying it heh. Basically it's not a good choice for my needs and room size. Really appreciate how honest they were. I'll probably wait and buy a PB2000 as everything keeps pointing me in that direction
