No, it's not that simple...
Methost said:
I was under the impression that "bi-amping" meant to combine to amp channels in to one to increase the power.
There are terms such as "division of labor"...but to make a long, boring story short and sweet, suffice it to say, it's not a simple thing to be done correctly...you can't just
double-up on the power outputs...unless you are fond of a brief lightshow and the lingering odor of burning epoxy and ozone.
Sticking with a two-way system for simplicities' sake, your loudspeakers need to present you with access to the woofers and the tweeters; two sets of terminals on each loudspeaker (usually strapped out for conventional use)...one amp drives the lower freqs to the woofers, the other the higher frequencies to the tweeters...and even that's not the
real deal...For that, you need to use an electronic crossover unit fed out of your pre-amp which separates the frequency bands, which then feeds ths amps, which drives the loudspeakers...and it comes out here. The loudspeaker's internal, passive crossovers must be disabled in this arrangement and crossover points, levels and slopes must be arrived at using some math and some test gear...not a real simple deal.
Rod Elliott has a really informative website on this and other audio subjects. You might even check this site for similar info.
jimHJJ(...clear as mud, eh?...don't worry, it's only a hobby...takes time and effort...)
