Wall outlet question
ematthews
ematthews
Simple question that I don't know the answer to. I have my Belkin 60 surge protector plugged into a single wall outlet. The Belkin has both my amp. pre and cd player plugged into it... On the same outlet I plugged my subwoffer in. Does this have any ill effect on a load or draw on the same outlet? Just want to make sure I am OK. My sub's cord isn't long enough to reach another outlet on the other side of the room so I am forced to use one outlet.
slipperybidness
slipperybidness
Assuming that your house is wired correctly, the worst that "should" happen is tripping a breaker. If you try to draw more power than is safe, the breaker should trip. I would say that if you aren't throwing the breaker then you should be OK.
Adam
Adam
Agreed. Most electrical lines are rated for 15 amps (I believe). If your outlet looks like a "normal" outlet with two vertical lines and a grounding hole, then it's a 15-amp outlet. It's possible that you could have a 15-amp outlet on a 20-amp breaker line, but as slippery mentioned, that would not be wired correctly - if that was the case, you could overload the outlet before tripping the breaker (or fuse, depending on your house).
I seriously doubt that you'd ever have a problem. I use to have my entire system running through a Belkin that showed the amps and voltage, and I don't remember ever seeing it go above 4 or 5 amps.
ematthews
ematthews
Thanks. Never has it thrown the breaker. I hope this house is fine. It's was built 9 years ago. Sometimes these newer houses are crap though.:D
Rickster71
Rickster71
If you're still curious, you can total the wattage of all your equipment.
A 15-amp circuit gets you 1800 watts. You'll never come close, since since your amp and sub will never draw full load.
Breakers trip thermally, so your type of load wouldn't get close to tripping a breaker. A linear load like two toasters would do it.
It is possible and legal to have 15-amp devices on a 20-amp circuit.
The code say's on a 20-amp circuit you can use either 15 or 20-amp receptacles. A 20-amp plug won't fit into a 15-amp device due to the plug's configuration. Receptacles don't carry the full circuit ampacity, the are attached with pig tails. So the device only sees the load of what is plugged into it.
Check your load center, you may have 20-amp circuits in that place.
Speedskater
Speedskater
A dual 15A receptacle has the very same internal parts as a dual 20A receptacle. So if a dual 15A receptacle is correctly wired in a 20A circuit, it can handle the total 20 Amps.
Rickster71
Rickster71
Yes, agree.
I was going to edit and elaborate; I'm always rushing when posting while at work. :D
A 15 amp receptacle is capable of feeding through the 20 amp circuit; even though they shouldn't be wired that way.
Pyrrho
Pyrrho
A 15-amp circuit gets you 1800 watts. ....
There is a lesson in that for people thinking about adding massive power amps to their systems. The circuit to which one plugs in one's gear is a limiting factor in the kind of power one can get out of it and send to one's speakers.
How far is that room from the panel? If it is a long run I would plug the sub to a separate outlet. I agree with everyone that from the loading stand point you should be well within the limit but during the coincidental peaks (the ATI and the Rythmik F12) you may have enough voltage drop that could affect performance.
slipperybidness
slipperybidness
My ears bleeding is usually the first limiting factor before getting to that kind of power :eek::D
Or at least my GF is the limiting factor.
big2bird
Chances are, the next closest receptacle is on the same circuit, rendering that a moot point.
Speedskater
Speedskater
Yes, agree.
Sure they should, it's standard operating procedure. OK there have to be two 15A receptacle's on the circuit. The only difference between a 15A & a 20A receptacle is the plug that can be plugged into the 20A unit.
big2bird
Why should I upgrade my listening room receptacles?
The typical receptacles in your home are rated at 15 amps. The receptacle we offer is rated at 20 amps which means that it contains larger metal elements for better power transfer and clamping to the plug that is inserted into it. These are what provide the improvements!
From Morrow Cables. BS in print.LOL
I know for a fact this claim is incorrect.
I need to show this to my buddy at Hubbell
big2bird
Hubbell makes some nice stuff.
Yes, they do. My comment was pointed at Morrow Cables, that sells them claiming they are heavier duty than their 15 amp receptacle. Simply not true. The interior parts are the same.
Speedskater
Speedskater
NO. Once again........
The dual 15A receptacle is rated at a total of 20 Amps!
The only difference between a 15A and a 20A dual receptacle is the type of plug that you can insert in the 20 Amp receptacle.
Rickster71
Rickster71
Just so we're on the same page.
Receptacles shouldn't be wired as 'pass through' devices. They should be added to the circuit with pig tails, so in case of the receptacle's failure or bad connection at one of its screw terminals, it won't cause the entire circuit to fail.
Why?
I still agree.
big2bird
Perhaps you need to re read my post. That is Morrow Cables claim, not mine. I have been an electrician since 1979. I KNOW better
