So I'm looking for some wall mounts.
They have Keyholes, which would be easy..but they are back-ported, so I figured you know, putting them directly against the wall isn't a super idea? I'm no audiophile though...
I've looked at Omnimounts...and @ 25$ a pop, I can say no thank you. I may end up only mounting two of them though. The back two, and keep the Front L / R on my Desk and Center under my Monitor.
Wall Mount Brackets
Monoprice has cheap, affordable ones that come in pairs, but no idea which would be good. Thoughts? I also saw these, bought on Amazon alot with the Energy Take, but once again, seem very...wall-hugging.
http://www.amazon.com/Universal-Satellite-Speaker-Brackets-Ceilings/dp/B000WXA17W/ref=pd_rhf_dp_p_t_1
Thanks for your help.
Also , I want some banana plugs for this setup.
I have about 85 feet of 16 Gauge Speaker wire or so, I figure enough for my very small room, I even measured, but what type of plugs should I get?
http://www.monoprice.com/products/subdepartment.asp?c_id=104&cp_id=10401
