Wall Mounting Advice
droht
droht
Any tips on wall mounting speakers like Usher S520s?
Weight 15 lbs each
Dimensions (w x d x h) 7.09" x 10.43" x 11.81"
They have no hardware or options for mounting. I recall seeing mounts that clamp on to sides of speaker, but none of those every struck me as good options. Also thinking I could add mounting hardware, but I'm not crazy about taking a drill to my Ushers.
Any thoughts or ideas? Thanks.
droht
droht
Thanks Curtis. I don't recall seeing that one before. It actually looks very strong and stable.
3db
3db
I use them to hold up my PSB Image 1B which are 12 lbs..using nothing but the ez-anchors. I'm not going thru any wall studs.
DaveHo
I've used the B-Tech BT77 with a number of different speakers. Very solid.
-Dave
colin.p
colin.p
+1 for the B-Tech BT77. Very solid and my speakers are 20lb a piece. My wife likes to use them as shelves also.:rolleyes:
Colin
