Variable loudness contour control - which model?
Discussion in 'Amps, Pre-Pros & Receivers' started by KEW, Apr 4, 2011.
  1. KEW Audioholic Spartan
    KEW
    Jul 12, 2009
    5,434
    1,943
    Jowjah
    I have always believed that a properly executed loudness control is a great thing. Using modern gear, I find the sound quality lacking until the spl is at 75dB or better.
    On my vintage amp, I feel the loudness contour is overblown at normal settings, but works very well if I engage muting (which is a -20dB switch, not a total mute) and turn up the volume to compensate. Naturally, the efficiency of the speakers also plays a role in this.
    Accordingly, I have always thought the variable loudness control, such as Yamaha uses for much of their stereo gear was a good way to go. I believe McIntosh and Denon may also offer a similar variable loudness control on at least some of their equipment at some point in time. Are there others?
    My real interest in this post is to get suggestions for a unit which has this feature. I have a good separate amp I could pair with a preamplifier or preamplifier section of a receiver, so that may be a good option. I would also consider used. When I look at used Yamahas, many have lots of pressure pad buttons, and I wonder how prone these are to getting dirty contacts?
    Thanks in advance for you comments on this.
    KEW,
  2. GranteedEV Audioholic Ninja
    GranteedEV
    Jul 14, 2009
    4,933
    2,355
    Calgary, Canada
    • Like Like x 1
  3. KEW Audioholic Spartan
    KEW
    Jul 12, 2009
    5,434
    1,943
    Jowjah
    Can anyone tell me some Denons that have this feature? I guess I'm looking for stereo components - preamp or either an integrated amp or receiver which has preamp outputs.
    TIA
    Grant,
    If I were to go with a miniDSP (and they incorporate this function) would that preclude using the miniDSP for other functions or can it handle sub crossover duties at the same time?
    KEW,
  4. jostenmeat Audioholic Spartan
    jostenmeat
    Feb 26, 2007
    6,789
    3,052
    If the miniDSP can do what you ask, even if not quite as well as some other things, that would be a great buy for the ease of measuring and EQing.
    If by Denon, you mean receivers? Well as far as HT receivers are concerned, I've never had the pleasure of trying any of the techs, and among them there is the Audyssey EQ, but I would perhaps look towards Dolby Volume as the deciding factor if only because I'm pretty sure M Code said it was the better tech of the two.
    • Like Like x 1
  5. KEW Audioholic Spartan
    KEW
    Jul 12, 2009
    5,434
    1,943
    Jowjah
    Thanks JM.
    On the Denon, I was hoping someone may have been familiar with their products over the years and know which models have the Variable Loudness control. I'm not sure if it was a brief foray, or of they maintained it across several models.
    Info has been pretty spotty from my internet searches, but Denon did have a Variable Loudness control in their gear for a period. If you look at the smaller knobs along the bottom, there is bass, treble, balance, and variable loudness:
    [​IMG]
    I have read in a single post on Audiokarma that the Denon did not implement this as well as McIntosh and Yamaha. If anyone has familiarity with their system, please share your experience.
    KEW,
  6. jeannot Audioholic
    jeannot
    Mar 27, 2011
    112
    13
    Ontario
    My favorite integrated amp is my Yamaha A-960. It does have a variable loudness control that works absolutely beautifully. I just love it, and you're right to go after this.
    The Yamaha variable loudness circuit is a simple set of passive components. 4 resistors, 4 capacitors, a stereo potentiometer. In case you ready to go "all the way" with this, here is the schematic. If you know a technician, it's likely he can put one of these together in a 2 cuin box in no time.
    Interesting side note: the A-960 was so close to the Carver patent with its X power supply, that it triggered a lawsuit, hence the A-960II
    • Like Like x 1
Share This Page
  • CEDIA
