Upgrading my soundsystem.
  • Thread starter Thread starter Bjornulf
Bjornulf
1
0
0
Hi, im upgrading my soundsystem and have already found the speakers and an reciver.
But I need your opinion on some stuff.
I currently got:
2 Proson 212
and a NAD C355BEE
this sounds pretty good at parties and stuff, but i want better.
I can now buy a pair of Infinity sm 155 and a NAD 916 too.
Should I do it?
And could i mix it all together as a settup with the infinityes at back, and the prosons in front, and maybe buy a good center later.
If you're going buy new equipment to integrate into your current system, I would make it very clear to the person selling it to you at the store that you want to bring it back if you don't like how it sounds. If you are buying from a store, they usually have a return policy and you should check it out before you buy just so you have the luxury of trying the stuff out first.
If you're buying the equipment off the street, well, not sure you'll be bringing it back if it doesn't fit your taste.
KM
www.myhometheatersecrets.com
