I have a temporary set of 5.1 speakers from Boston Acoustics (4x CR57, and CRC7, and a sub whose model escapes me at the moment, but its not important) that I plugged into my new TX-SR605. For some reason, when I first did the Audyssey calibration, it is crushing the high frequency sounds.
This problem exists entirely within the Audyssey's equalizer. I am not sure what is causing it to skew the sound in favor of the lows. Somebody on AVS suggested that the frequency response curve the Audyssey is using favored the lows on his setup, and he just changed it to fix this problem.
The problem in my case is that the 605 doesn't seem to have an option to adjust this. I could just turn off the audyssey equalizer, but then I have no idea what I am doing when it comes to tuning an equalizer by hand.
Does anybody have any idea what I can do to resolve this? Basically the sound problem I am having is that sounds like higher instrument notes (piano and light brass in particular) sound all hollowed out and muffled, but when I turn the equalizer off it sounds sharp and clean. I already tried moving the speakers around in several different configurations, and tried mounting the microphone to a tripod for calibration as well. Nothing seems to work.
