Sorry for the late arrival, but I just saw this thread for the first time today.
Mat said:
I have decided to try the
CAT 5 - V1 Four Twisted Cables DIY speaker cables as described in
http://www.audioholics.com/techtips/setup/interconnects/DIYSpeakerCablesp1.html
Figure 7, Typical Cable Ends Finished for Testing shows the terminations.
The Question
Instead of terminating as shown in Figure 7, would it be a good idea to try to take one 24 gauge wire from EACH 24-gauge-twisted-pair to the ground connection and the remaining to the positive connection? So instead of running two CAT 5 cables to one connection, I would run four 24 gauge wires from each of the CAT 5 cables to form the ground connection (and the remaining 24 gauge wires to form the positive end).
By using each twisted pair as a + and -, opposed to using all eight wire in a cable as + and all eight in another cable as - does not gain much or sacrifice much either, unless your amp goes buggers with high capacitance cables. A ten foot cable using each twisted pair as a + and - could have as much as 5000 picofarads (maybe more maybe less, but not much less and maybe a lot more) of capacitance. By using the V1 as shown, capacitance will be an order of magnitude lower (450 to 500 pF total for a ten foot cable).
The RFI/EMF rejection you get by using each twisted pair as + and - isn't as significant a gain over the V1 because of the amount of current flowing through the wire. The inductance of the V1 is higher, but only a little.
The V1 is now officially known as the Biohazzard 14, because it is equivelent to 14 gauge wire (actually it's 13 awg, but I've already hampered it by calling it Biohazzard).
HowY said:
but MY experience with usin' a cat 5 wire to push
audio for a spell was less than desireable.
Next time try using more than two 24 awg wires. The designs I've shown are equivelent to large gauge wire.
HowY said:
Quick to distort and even presented some real
strange harmonics through the wall!....
Most folks here use speakers as transducers, not drywall.
