just-some-guy
just-some-guy
are the cheap cables any good(enough) ?
i don't want to buy a $10-20 cable, just to trash can it in 1 year, or so.
so, will a cheaper one work fine ?
Adam
Adam
There are definitely cables that cost less than that amount that are good. I'm sure that there are also some inexpensive cables that suck. ;)
The ones at Monoprice seem very well built. How long of a cable do you need? Here is a six-foot cable for under $5 (but I don't know how much shipping costs).
lsiberian
lsiberian
If you have a digital coaxial you can use RCA cable for the run too.
