Would like to experiment with doing some analysis in my living room theater, but I dont want to spend any money. I downloaded the free REW measurement program to my surface pro, plugged in a blue snowball mic which i placed in my primary listening position, and plugged the surface into the an hdmi in on my receiver. I used to program to run sweeps and the response I got was actually really flat with just a few peaks and dips which I found to be a bit suspect being that I was running without any room correction software.
I have a lot of learning to do about how to properly calibrate the equipment and the software, but my main question is...
Will my Mic
http://www.amazon.com/Blue-Microphones-Snowball-Condenser-Microphone/dp/B006DIA77E/ref=sr_1_2?ie=UTF8&qid=1453754465&sr=8-2&keywords=blue+microphones+snowball
Do correction of its own on the incoming audio signal? Should I use a less forgiving mic?
Just started on all this experimenting and I know I have a lot to learn.
