Wow. I am still the one and only person who has 11 speakers in this poll?! (2 subwoofers, as well
I'm definitely curious to find out exactly how Dolby Atmos is going to work at home. My guess is that it will be rather similar to how DTS' entire hierarchy of audio formats works. What I mean is, I'm guessing the content itself will have to be encoded in a new Dolby Atmos codec. If your AV Receiver or Processor has the capability to decode that codec, then you will be able to enjoy the full Dolby Atmos soundtrack. But if your AV Receiver or Processor does not have a Dolby Atmos decoder, then it will default to the "bed" or "core" audio layer, which I would assume will be 5.1 or 7.1 Dolby TrueHD?
If DTS ever gets their -MDA format going, I'd certainly expect it to work the same way that DTS has layered new formats on top of existing "Core" formats all along. If a disc has a DTS Neo:X 11.1 encoded soundtrack, it will play back using 11 speakers plus the subwoofer channel so long as you have the DTS Neo:X decoder. But if you have "only" 7 speakers, it just plays as regular DTS-HD Master Audio in 7.1. Makes perfect sense to me that DTS-MDA would be a very similar situation.
What I really wonder about, though, is whether any sort of new matrix processing will be added to the Dolby Atmos suite for the home market. If someone is going to go to the hassle and expense of adding 9, 11, or even 13 speakers to their room, I can't imagine they're going to be happy with only ever being able to use all of those speakers strictly for Dolby Atmos encoded recordings!
In the case of DTS Neo:X, it can "expand" any existing soundtrack - from 7.1 all the way down to just 2-channel stereo - to use all 11 speakers. Obviously, it does a better job of making all 11 speakers sound discrete with actual DTS Neo:X encoded content. But at least there's a way to make use of all 11 speakers, regardless of the number of channels in the original recording.
The other bit of confusion I'm predicting is with the 13 speaker pre-outs that the new Denon and Marantz models are showing on their back panels. We're going to have this crazy mismatch of the number of pre-outs, the number of speaker binding posts (or XLR outputs), the number of internal amplifier channels, and the actual number of channels that the AV Receiver or Processor can output!
We already faced this with the Denon AVR-X4000, Marantz SR7008, and Marantz AV8801. All of those models had 11 speaker pre-outs (plus 2 subwoofer outputs), but only the AV8801 Pre/Pro could actually use 11 speakers simultaneously. Despite having 11 sets of binding posts and 11 speaker pre-outs, both the AVR-X4000 and SR7008 could only ever play a maximum of 9 speakers simultaneously. You could have 11 speakers all connected, but you would then have to decide which 9 out of those 11 speakers you wanted to use at any given time. Even crazier was that the AVR-X4000 only had 7 internal amplifiers. Talk about confusing!
Onkyo's offerings were a little bit less confusing, but not much. The TX-NR3010 and TX-NR5010 gave you 9 internal amplifiers and 11 speaker pre-outs. If you wanted to use 11 speakers simultaneously, just connect an external 2-channel amp to power the Front Wide channels, and you were good to go. It could still be confusing, though, because those models still had 11 sets of binding posts. So you could have all 11 speakers physically wired to the TX-NR3010 or 5010, but if you did that, you could only power 9 out of those 11 speakers simultaneously. Oy.
But now, with the AVR-X4100, AVR-X5200, AVR-X7200, SR7009, AV7702, and AV8802, things are getting really nuts!
So...
--> Denon AVR-X4100: 13 speaker pre-outs (plus 2 subwoofer outputs), 11 sets of binding posts, 7 internal amps, and it appears as though you can run a maximum of 9 speakers simultaneously.
--> Denon AVR-X5200: 13 speaker pre-outs, 11 sets of binding posts, 9 internal amps, and appears you can run a maximum of 11 speakers simultaneously.
--> Denon AVR-X7200: 13 speaker pre-outs, 11 sets of binding posts, 9 internal amps, and appears to run a maximum of 11 speakers simultaneously.
Differences between the X5200 and X7200? Looks as though the X7200 gives you 7.1 analogue audio inputs, a 2nd component video output, 32-bit DACs, and beefier internal amps.
But that AVR-X4100 is nuts! 13 pre-outs but only 7 internal amps and 9 simultaneous speakers? So...5.1 plus 4 Height speakers for Dolby Atmos?
Over at Marantz...
--> Marantz SR7009: 13 speaker pre-outs, 11 sets of binding posts, 9 internal amps, and appears to run a maximum of 11 speakers simultaneously.
The SR7009 appears to actually be closest to the Denon X5200, but it adds 7.1 analogue audio inputs. Otherwise, it's closer to the X5200 than the X7200.
--> Marantz AV7702: 13 RCA pre-outs, 11 XLR outputs, appears to run a maximum of 11 speakers simultaneously
So this looks to be an SR7009 in Pre/Pro form. Exact same compliment of inputs, same 24-bit DACs, but with 11 XLR outputs instead of speaker binding posts and 9 internal amps.
Finally...
--> Marantz AV8802: 13 RCA pre-outs, 13 XLR outputs, might this actually be able to run 13 speakers simultaneously?
Out of all of them, the AV8802 is the only one that suggests to me that 13 speakers simultaneously might be possible. With all of the others, either the speaker binding posts or the XLR outputs make it pretty clear that you're choosing to run EITHER a 2nd pair of Height speakers OR a pair of Front Wide speakers. Take your pick and you can have 11 speakers running simultaneously. But I'm betting it's a lot like the AVR-X4000 or SR7008 - you've got those 11 speaker pre-outs, but can only run a maximum of 9 speakers simultaneously. Now I'm feeling pretty certain that you'll have the 13 speaker pre-outs, but only 11 speakers simultaneously is ever possible.
But the AV8802 -- having those 13 XLR outputs and not forcing you to make a choice, it makes me think that maybe it really does have 13 DACs in there and might actually be able to run all 13 speakers simultaneously. Now how might Dolby Atmos at home handle that?
To be honest, I haven't been all that impressed with the addition of the Front Height speakers to my system. I could remove them and be perfectly happy. But I've actually quite enjoyed the addition of the Front Wide speakers.
So DTS Neo:X and Audyssey DSX both make use of the Front Wides. Reading between the lines, it appears as though the plan for Dolby Atmos at home is to use our traditional 7 speaker setup, and then add 4 Height speakers. That might be very similar in the end to the speaker setup that Yamaha has had for a long time with their Front and Back pairs of "Presence" Height channels. I've also heard the Auro 3D Audio guys talk about suggesting that a traditional 7 speaker setup with "quadraphonic Heights" would be their recommendation for home setups. So at least there's some consensus. And if you look at some of the DTS Neo:X diagrams, it appears as though they were planning on one pair of Front Heights and one pair of Back Heights originally, too.
But what might become of my Front Wide speakers then? Will they only remain in use if I select DTS Neo:X or Audyssey DSX as my listening mode? If I switch over to Dolby Atmos, will it silence my Front Wide speakers in favour of using 4 Height speakers? It certainly looks like that's the plan.
But hey, there's that DTS-MDA format out there in the ether. DTS might build upon Neo:X by adding Back Height speakers to give a total of 13 speakers in all!
Whatever it ends up being, I'm down with it. I can't say I've really been all that blown away by Dolby Atmos in theaters, but it's cool on rare occasions when it's used well - like Cerebro in X-Men: Days of Future Past. I've already put 11 speakers and 2 subwoofers in my tiny apartment theater. What's 2 more? haha
- Rob H.
