What you originally did is about the worst insult you can give any amp. Your are lucky you did not blow both of them.
As to your second problem, we don't know where the damage trail ended. Also without a circuit, I could not begin to tell you how to power the preamp section without the power amp section. .
Thanks for working with me on this. Today is Sunday and I worked on this whole day and the progress is really good. I have managed to turn-on the preamp section (both channels).
Since I knew that when i was doing the experiment, only one channel of this amplifier was connected, I was sure that the problem will be with just one channel. So I alternately connected the power supply wires from the bridge network to both the channel and the good news is that the right channel is working fine and there is a problem with left chanel power amp section. So if power is suppied to just the right channel power amplifer section. This channel works fine and so does both channels of the the preamp section. This is because there is an electronic switch that gets activated if there is power supply to the power amp section.
So now the preamp section is just working fine and I have connected a seperate power amp (external) to my system.
Right channel of the integrated amplifier is also working fine.
But if I give power supply to the left channel of power amp section the fuse blows.
NOW what do you think is the problem with left channel power amplifier section ? Is the transistor burnt ?
How many bridge rectifiers are there in the power supply? If only one then there will be voltage regulators for the power amp and preamp section and my be a few others. I suspect you have cut the power to the voltage regulator section of the power supply.
There are 2 transistor per channel on the power amplifier section i.e. 1 each 2SA1494 and 2SC3858. I will try to send picture of the power amp section.
