SVS PB13-Ultra Vs. Martin & Logan Decent i
Discussion in 'Subwoofers' started by derek44, Dec 23, 2008.
  1. derek44 Enthusiast
    derek44
    Dec 18, 2008
    10
    0
    Please help me decide.
    If price was not a deciding factor between these two and the decision was based purely on performance. Which one of these would you purchase. Which one brings the cleanest thunder to a movie or cd?
    thanks for your input!
  2. Chopin_Guy Senior Audioholic
    Chopin_Guy
    Aug 13, 2008
    666
    168
    Houston
    The PB13 will wipe the floor with the Logan Descent and for the retail price of the Descent i you can get two Ultra's which will make the Descent seem like a 100 watt 10" Sony subwofer.... :eek:
  3. jostenmeat Audioholic Spartan
    jostenmeat
    Feb 26, 2007
    6,789
    3,052
    The Descent-i is a very good sub. Like a 10" Sony sub? WTF fanboi?
    WTheF___ pays retail anyways? Yeah, I know, ID's retail = real cost.
    You can crank a Descent-i so that the walls are shaking, and put a nickel on its side on top, and it won't even move.
    • Like Like x 1
  4. bandphan Banned
    bandphan
    Dec 13, 2007
    6,619
    2,363
    in a haze
  5. croseiv Audioholic Samurai
    croseiv
    Aug 6, 2007
    2,395
    629
    Somewhere on planet Earth
  6. bandphan Banned
    bandphan
    Dec 13, 2007
    6,619
    2,363
    in a haze
    Please note that is not the descent i linked its the depth. And while some think the ultra is better to say that an ultra would wipe the floor with the descént is not at all True.
  7. Chopin_Guy Senior Audioholic
    Chopin_Guy
    Aug 13, 2008
    666
    168
    Houston
    Sorry to spark so much nonsense here....
    And forgive me that you cannot tell I was be facetious Josten, but I am fully aware that the Descent i is a very good sub....but I would not consider the performance given the price justified especially when compared to the price/performance of ID products like the SVS....and I do understand that the OP said price was not an object but nonetheless, as I pointed out, the retail of the Descent buys you two Ultras or if you
    want to put even more in your pocket get some room correction/eq (Berinhger, Velo SMS, .....) with one Ultra and you will have very well tailored sub in your room and a unit that will likely outperform the Descent i....
    And if we are going to be making b*tchy comments on here instead of really trying to help Josten.....WTheF cares what a nickel does on a sub when its cranked up....what does the have to do with performance or sound quality aside from NOTHING....
    • Like Like x 1
  8. croseiv Audioholic Samurai
    croseiv
    Aug 6, 2007
    2,395
    629
    So why did you post the specs for the depth??
  9. croseiv Audioholic Samurai
    croseiv
    Aug 6, 2007
    2,395
    629
    Okay, after a little more reading, it does appear that these two subs may be roughly equivalent, with the decent being twice as expensive as the Ultra. Based on that, I would get dual Ultras and be done with it (Oh I did :)).
    • Like Like x 1
  10. bandphan Banned
    bandphan
    Dec 13, 2007
    6,619
    2,363
    in a haze
    Was trying to get across that the design for both is good
    i agree with the dollar to performance ratio:)
  11. ppomerantz Audiophyte
    ppomerantz
    Dec 24, 2008
    1
    0
    NJ
    New user here. I have been upgrading Home Theater recently and Sub is next in line. Recently got used ML Mosaics and Fresco for Fronts and Center and really enjoying them. Looking at a ML Grotto, Hsu VTF2-MK3, or ED A2-300. Would buy the Grotto used for around $600, Hsu running around $550 and ED would be much less. My room is not that large. I see you have an Abyss along with other ML's and wonder how you like the Abyss and did you ever audition a Grotto or Grottoi. I would have PM'd you but don't have 5 posts.
    Thanx
  12. sgtpepper9 Audioholic
    sgtpepper9
    Apr 23, 2008
    179
    21
    Louisiana
    Can't say anyting about the martin logan sub since I have never heard it. But I have never heard my Ultra distort one bit even at some ridiculous high dB level and I have a pretty large and open room. I can only imagine how insanely awesome 2 would sound...
  13. bandphan Banned
    bandphan
    Dec 13, 2007
    6,619
    2,363
    in a haze
    Pm sent for u
  14. Tod Audioholic
    Tod
    Sep 5, 2006
    155
    9
    Tahlequah, OK
    One problem you'll likely run into here (if you can't tell) is that most people have probably not actually heard both of the subs, let alone spent enough quality time to make their own judgments. That leaves basically specs and $$$, and it is true that the idea of 2 Ultras vs. 1 Descent for the price could tip the scales.
    I don't have the Descent i, just the original, but I got it for $1700 used (the price shipped of the oak Ultra I was considering at the time), and have suffered not the slightest, tiniest bit of buyer's remorse or upgraditis. I have not heard an Ultra personally either, so maybe that doesn't mean much, but there's never a moment when I wish I had more or paid less. The only upgrade I'm even considering is when I get around to it, perhaps getting a Descent i and moving my original one to my 2-channel set up. I have some other speaker upgrades on the list first though...
    Anyway, if you don't mind the idea of used things check out Audiogon. You can save considerably if you go with the Descent.
    Tod,
  15. derek44 Enthusiast
    derek44
    Dec 18, 2008
    10
    0
    Thanks for all the feedback here. Sounds like either way, it will rock, but if i want to destroy my house sounds like 2 SVS subs would be the way to go :) not sure if the wife would go for two of those bad boys. sounds like on a one to one comparison they both rock, but the ML will be twice the costs. Hope you all have a Merry Christmas!
Share This Page
  • CEDIA
