surround speaker placement doubt ****
suniltgeorge
hey im putting up a 12.5 by 12.5 feet home theater room ..i am probably getting the klipsch rf 52 II home theater speakers .. due to placement issues i cant directly place the surround speakers right behind the seating but well above proly above door level .. is this okay? .. main question is .. is the height of placement okay ? ..
ParadigmDawg
ParadigmDawg
If that's your only choice then it will have to be ok. It should work just fine. My surrounds are in the ceiling as that was my only choice and it works fine.
A bigger concern is a room that has square dimensions, That should be fun trying to get a smooth response in there.
suniltgeorge
the setup is with acoustics .. is there still problems ? what do u mean ?
