Important Note for 64met.
Hi 64met,
Just to make sure that you understand that there are two ways to fix potential proplems with your Integra DTC-9.8
* Your Pre/Pro contains a microcomputer for signal processing and control functions. In very rare situations, severe interference, noise from an external source, or static electricity may cause it to lock up. In the unlikely event that this happens:
#1. Turn your pre/pro OFF (Standby). Unplug the power cord from the wall outlet, wait at least 5 seconds, and then plug it back in again.
(You did this one to no avail.)
* If solution #1 or you can't resolve the issue yourself, try resetting the Pre/Pro before contacting your Integra dealer:
#2. To reset the Pre/Pro to it's factory defaults, turn it ON and, while holding down the [VCR/DVR] button, press the [STANDBY/ON] button. "Clear" will appear on the display and the Pre/Pro will enter Standby mode.
Note that resetting the Pre/Pro will delite your radio presets and custom settings.
--> I don't know if you try solution #2, but if you did not, please DO IT.
Good luck,
Bob
