Is subwoofer level matching recommended using Audyssey MultEQ XT32 room correction ?
surveyor Audioholic Chief Oct 14, 2016 #1 Is subwoofer level matching recommended using Audyssey MultEQ XT32 room correction ?
speakerman39 Audioholic Overlord Oct 14, 2016 #2 surveyor said: Is subwoofer level matching recommended using Audyssey MultEQ XT32 room correction ? Click to expand... Audyssey MultiEQ XT 32 w/Sub EQ HT sure does. I level matched both of mine before running Audyssey. Mine were placed equidistant from my MLP. That seemed to make things much easier to dial in just right. It is all about tweaking as Audyssey is a very good starting point inmho. I did NOT have to turn the gain/volume knob up very far to reach 75 db on my PSA S1500's. Usually ending up around the 9:00 o'clock position. Hope this helps answer your question. Cheers, Phil Last edited: Oct 15, 2016
