subwoofer humming :(
Discussion in 'Subwoofers' started by karrar55, Apr 24, 2013.
  1. karrar55 Audiophyte
    karrar55
    Apr 24, 2013
    3
    0
    hello everyone i have probably the weirdest way of having my home theater subwoofer fail on me. ok so i was charging my phone and someone called me so i go to answer it and as soon as i touch the phone i got a strong electric shock from it because i was charged from my carpet. when that happened my subwoofer (that is plugged to a different wall outlet near my phone charger) started humming loud. i dont know why it started humming.
    I have a samsung ps-aw730 powered subwoofer.
    what i have done so far:
    1. plugged subwoofer to different outlet. no change
    2. did a speaker test. no change
    3. opened up the SB everything seems ok. no fuses burned or anything.
    4. audio wire is good too
    if you guys can help me out in fixing my sub, that would be greatly appreciated thanks!
  2. markw Audioholic Overlord
    markw
    Nov 26, 2003
    11,235
    3,051
    Joisey and Texas
    Does it hum when nothing is connected to it and it's only pluged into the wall?
  3. j_garcia Audioholic Jedi
    Jul 11, 2005
    26,560
    5,735
    How is it connected to the receiver? Disconnect it from the receiver and see if the hum goes away, if it does, it may be ground loop. If it doesn't, the sub is the problem. The most common cause of this IMO, is typically the CATV feed - try disconnecting that from the system and if the hum goes away, it is most likely ground loop.
    http://forums.audioholics.com/forum...ground-loops-eliminating-system-hum-buzz.html
  4. AcuDefTechGuy Audioholic Slumlord
    Jul 10, 2007
    19,870
    4,340
    Oklahoma City
    If it is as disturbingly loud as I think, it's probably not ground loop, especially with absolutely nothing changed or even touched on the Audio system.
    If the sub hums very loudly with no other wires connected (except power cord), then I say the sub amp probably has malfunctioned.
  5. j_garcia Audioholic Jedi
    Jul 11, 2005
    26,560
    5,735
    That's why we both asked if it hums with nothing connected. I don't think it is ground loop either, sounds like the amp.
  6. karrar55 Audiophyte
    karrar55
    Apr 24, 2013
    3
    0
    hey guys thanks for all the replies...when i plug it in without the audio wire to the electrical outlet it makes the humming noise too. my sub has a volume on it so the humming can be regulated its not a uncontrollable humming
  7. Speedskater Full Audioholic
    Speedskater
    Feb 7, 2013
    383
    61
    It first I thought that this was the old story about the dog barking just before the phone rang.
    Let's get to troubleshooting:
    a] Turn everything off.
    b] Unplug all the sub wires.
    c] Plug in the sub AC cord & turn only it on. Does it hum?
    d] If yes then make a shorting RCA plug by taking an old & cheap RCA interconnect, cutting it to about 6 inch length, strip off some insulation and twist the center and shield together.
    e] Turn-off the sub, insert the shorting plug and re-power the sub. Does it hum?
    f] If yes, send the sub out for repair.
  8. karrar55 Audiophyte
    karrar55
    Apr 24, 2013
    3
    0
    yes it does hum. guess i gotta get it fixed. thanks guys.
  9. TLS Guy Audioholic Overlord
    Oct 30, 2007
    13,433
    5,174
    Benedict MN
    Unfortunately your static charge blew the sub amp via the neutral line. The switching power supplies in these sub amps are prone to blow very easily. Unfortunately I doubt it is worth the cost of repair.
  10. afterlife2 Audioholic Spartan
    afterlife2
    Oct 7, 2011
    5,720
    1,886
    Don't bother getting It fixed. TLS Guy Is always on point. I'd say give us a budget/room size and we can help you get a good reliable sub.
  11. einteractive Audiophyte
    einteractive
    Apr 24, 2013
    5
    0
    A subwoofer humming can be caused of two reasons: it's either coaxial cable interference from the cable TV or satellite service provider; or a grounding problem between the sub and the audio-video receiver that drives the home theater system.
  12. markw Audioholic Overlord
    markw
    Nov 26, 2003
    11,235
    3,051
    Joisey and Texas
    I can think of at least one other reason.
    The amplifier died. Unfortunately, it does happen.
  13. Bizarro_Stormy Audioholics Whac-A-Mole'er™
    Bizarro_Stormy
    Dec 11, 2010
    300
    125
    SeaLab
    Well... one more reason...
    It could be bored...
    I tend to hum when I'm bored...
    that and smoke...
    If your sub starts humming AND smoking, it could be trying to tell you something...
  14. caper26 Full Audioholic
    caper26
    Feb 26, 2010
    289
    81
    Annapolis Valley, NS
    First guess is something shorted on the amp.
    last thing to try is to use an extension cord with 2 prong, so that the grounding prong of your sub power cable is not connected. See if the hum is still there. I doubt it will work in your case due to the backstory. Always worth exhausting all efforts first.
    You could price out a replacement amp. I did that for my monitor audio amplifier. $1399 MSRP sub with a mild hum was fixed with a $280 plate amp.
Share This Page
  • CEDIA
