Sub at -12db after Audyssey
Discussion in 'Subwoofers' started by AgentX, Jul 13, 2017.
  1. Pogre Audioholic Samurai
    Pogre
    Jul 29, 2016
    2,702
    726
    Turn your gain down on the back of your sub until Audyssey sets it to -7, -8, -9... as long as you're not still getting -12. You're reporting boomy bass and your receiver has trimmed the levels as much as it can.
  2. William Lemmerhirt Audioholic General
    William Lemmerhirt
    Jan 8, 2017
    1,341
    286
    Had a tricky time getting specs for this sub. Anyway, it's a low power ported 9" with a port on the bottom so it shouldn't be hard to tame. The frequency response I found listed though from 35hz on up. Based on that and a typical "bump" in the response that's built in to many smaller subs I will guess it will always sound a little boomy. However some quick reading of reviews made it seem like that wasn't so much a problem. Get the level and placement right and then see.
  3. NINaudio Audioholic
    NINaudio
    Jun 26, 2017
    136
    27
    That's strange. I have a Denon AVR-X4000 and it asks me to set the gain so the sub is in the 75db range before it does any measurements. For me, that is at 1/4 of the max gain. Every time I've run audyssey like this it sets my sub trim at -6db.
  4. William Lemmerhirt Audioholic General
    William Lemmerhirt
    Jan 8, 2017
    1,341
    286
    Yeah, I'm surprised his didn't ask for 75db too. Too many factors involved to use any arbitrary numbers. Curious where he ends up. Btw, NIN artist shuffle on Spotify currently.
    • Like Like x 1
  5. Pogre Audioholic Samurai
    Pogre
    Jul 29, 2016
    2,702
    726
    Did he mention which receiver he had? My X1200W had XT, but it wouldn't set sub levels. I think you need XT32 for that. My SR6011 does it.
  6. William Lemmerhirt Audioholic General
    William Lemmerhirt
    Jan 8, 2017
    1,341
    286
    Even my older 808 Onkyo sets the sub level. Not EQ though.
  7. lovinthehd Audioholic Spartan
    Sep 11, 2012
    5,899
    907
    My old Onkyo with XT (RC370) lets you set sub levels prior to running Audyssey. I think it depends on the specific implementation by the avr manufacturer, as with other things Audyssey, probably lower models get less features/flexibility?
    • Agree Agree x 1
  8. Pogre Audioholic Samurai
    Pogre
    Jul 29, 2016
    2,702
    726
    Well, look who's Mr. Quotey McQuote now! :p
    I might have misunderstood. All of my receivers have set a trim level, but only my 6011 (XT32) has had me adjust the gain on the subs if they're a little hot. My Denons would let me know by setting the trim level to -12. I would dial back the sub gain until it trimmed them to -9 or so. Mine are both around 1/4 gain right now. I think op said he had it at 1/2?
  9. Pogre Audioholic Samurai
    Pogre
    Jul 29, 2016
    2,702
    726
    That's my guess. I posted above what I did when it didn't have me set sub levels before Audyssey.
  10. William Lemmerhirt Audioholic General
    William Lemmerhirt
    Jan 8, 2017
    1,341
    286
    That's quotey quoterton to you mr!!!!! Lol
    • Funny Funny x 1
  11. AgentX Enthusiast
    AgentX
    Jul 8, 2017
    13
    1
    Ok, so I had to run Audyssey about 4 times which means this thread is now 15 years old. But to anyone who followed this, I managed to get the sub level to about -7.5 and I had to set the volume knob to about the 8 o'clock position which is about 16% of the max I think.
    The bass is far more acceptable now. So I'll watch a few more movies and see how it goes.
    Thanks for all your input.
    • Like Like x 1
  12. William Lemmerhirt Audioholic General
    William Lemmerhirt
    Jan 8, 2017
    1,341
    286
    Lol. That's why I turned 50....
    Interested to see what you think now, after a couple movies.
  13. Roen Junior Audioholic
    Roen
    Apr 3, 2017
    92
    6
    If we're using an SPL meter for test tunes, do we calibrate to 75 db at whatever receiver volume, or 85 db at 0 db on the receiver?
    Roen,
  14. KEW Audioholic Spartan
    KEW
    Jul 12, 2009
    5,788
    2,077
    Jowjah
    KEW,
  15. lovinthehd Audioholic Spartan
    Sep 11, 2012
    5,899
    907
    75dB with fixed test tones for most avrs I believe...which is generally 30dB down from peak ref level of 105dB (0 on relative volume scale if avr has such).
  16. William Lemmerhirt Audioholic General
    William Lemmerhirt
    Jan 8, 2017
    1,341
    286
    Yeah this. Iirc, 85 used to be the number but the consensus was that it was too loud so auto test tones were set to output at 75 when measured. For the question roen is asking, either will work as long as they're all set the same.
    • Agree Agree x 1
  17. Roen Junior Audioholic
    Roen
    Apr 3, 2017
    92
    6
    Is it 75 DB at 0 on the receiver or 75 DB at whatever setting on the receiver when using test tones.
    Roen,
  18. lovinthehd Audioholic Spartan
    Sep 11, 2012
    5,899
    907
    With my avrs the master volume control does not matter during test tones, it is preset to the -30dB level from peak.
  19. Roen Junior Audioholic
    Roen
    Apr 3, 2017
    92
    6
    Maybe it's a Yamaha specific thing then.
    Roen,
  20. Roen Junior Audioholic
    Roen
    Apr 3, 2017
    92
    6
    I ended up using YPAO, and playing around with the gain until I got it to set at -5.0. That was about a little north of 9 o'clock. It turned out that was a little less bass for my liking, so I adjusted the gain back up to a little before 12, keeping the receiver settings as per YPAO.
    Strangely, YPAO set my front speakers to large with crossover set at 40 Hz., even though a sub was present. I have a 2.1 system at the moment. I had to switch my speakers back to small and my crossover back up to 90 Hz.
    Roen,
Share This Page
  • CEDIA
