Stuck Between 2 stereo speakers
G
gotxquattro
I am a new poster here so hello to everyone. I work for a home entertainment company and am always around these speakers. I am torn between 2 and I know there both excellent speakers but wanted everyone elses opinion is. The 2 speakers that are keeping me mentally torn are the B&W CM9 floor standing or the Martin Logan Vantages. My company and store sell both and I have had extensive time with both but I cant seem to make up my mind. Please everyone let me know what you think !
- Rizzo
I
InTheIndustry
- Rizzo
1: What does the owner of your company or salemen think is best for your particular needs?
2: What are your particular needs? Room size, multichannel, related equipment these will be used with (like a subwoofer), etc., etc.?
G
gotxquattro
the other guys I work with say either or because they truely are great speakers. I will be using them for movies, music , video games and pretty much everything. if i get the CM9 I will get a sub. Otherwise going with the logan vantages they have built in 8" subs
- Rizzo
GranteedEV
GranteedEV
Built in 8" sub means nothing... it just means the vantage design struggles to reproduce mid-bass so it needs a traditional driver to do handle that aspect. Although 34hz extension is nice, you're still missing nearly an octave of sound, not to mention subsonics You will still need a true dedicated 12" or 15" subwoofer for real bass. I recommend two Rythmik FV25s.
Anyways I would get the Vantages personally. What is the impedance graph on them?
G
gotxquattro
Built in 8" sub means nothing... it just means the vantage can't reproduce bass so it needs a traditional driver to do it. You will still need a true dedicated 12" subwoofer for real bass.
trust me I understand it would still be nice to have a separate sub I setup home theater systems all day long but the issue is for now im in a 15x20 room so its going to be loud no matter what for bass response
- Rizzo
JerryLove
JerryLove
Small room and heartier? I would get the com (or com). For a larger room where I could play with room acoustics: I couldn't resist playing with the panels
Z
zumbo
If the option is B&W and a powered sub, or ML without, I vote B&W.
No contest. You will just be missing out without a stand alone powered sub. Not to mention placement issues.
G
gotxquattro
You would say the B&W just because im not using a sub? What about just speaker quality between the both I know there totally different but thats the real issue at hand. So forget about the sub for now
- Rizzo
jamie2112
- Rizzo
I like the B&W because the sound is more forward than the ML's.I am not a ML fan even though one of my mastering friends use ML's to check his mixes before turning them in.
Z
zumbo
- Rizzo
I believe the speaker quality has been touched on. Looks as though ML had to add 8" subs to accommodate for lack of FR.
I have not heard the ML, just judging by your remarks of being torn between the two. If it is that close, and you will get to ADD a powered sub to one of the pairs, then...
zieglj01
zieglj01
Go with the one that you like best for music - if you still can't decide,
then take out a quarter and flip it. Heads for Martin Logan and tails
for B&W.
Boerd
- Rizzo
If you want to play the speaker loud planars aren't that good. That being said is hard to beat a planar from 400Hz to 4Khz. Personally I'd go with Martin Logan - it may not be that loud but sounds great.
