fuzz092888
fuzz092888
Looking for a good straight edge for the circular saw. Since a tablesaw is out of the question ATM, I was thinking I could get a good straight edge for my circular saw.
I have one of these, but it's only good for 50" or less and can be a bit cumbersome to use because even though it clamps, it still needs additional clamping to really stay put.
http://smile.amazon.com/E-Emerson-Tool-C50-All-In-One/dp/B003TXSAHU?ie=UTF8&keywords=straight edge&qid=1459708739&ref_=sr_1_5&sr=8-5
I was looking at this. It's a little longer, but looks like it could last.
http://www.contractorsdirect.com/Barwalt-8ft-Aluminum-Straight-Edge
fuzz092888
fuzz092888
Alex2507
Alex2507
Hmm, I'll have to see what I can do with the straight edge I have and see if I can make one of those. Thanks.
I just use a 4' level for most stuff. Richard's saw sleds are great when you're going to be making a lot of cuts. If I was looking to spend a lot for the cool factor I'd be looking at FesTool (sp) that OSA likes.
fuzz092888
fuzz092888
No way I can throw down Festool money until after something smaller and shinier gets put on a finger round these parts. The only reason I got away with the subs is becasue they were part of a GB a year ago.
Any thought to this? Somebody at work recommended this to me
http://www.amazon.com/Bora-543050-Locking-Straight-Precise/dp/B00PQP12NI
I'll have to see if my local HD has that in stock to see if I can take a look at it in person.
Alex2507
Alex2507
You might have to order it. It's a cheap 8' or 98' to be exact, straight edge that doesn't stay 8' long. I've never seen anybody with the fancy ones at work. I use those 7" Vise clamps with swivel feet on a level and that's the end of that. HD has those clamps for sure. $20 each. The saw sledis better because you can see where the blade is going to cut. To make a saw sled you use the factory end of a cut-off. I can't type it out right now but that is the best way. I'm sure you can follow the instructions but I can help with that if you need it.
Congrat's on the engagement. First wives are a blast. :D
lsiberian
lsiberian
I have the same one you have and never have slippage issues, but getting it to line up correctly is a nightmare. Anyway you could do an outfeed and infeed table saw. I can barely fit my saw on the current balcony. I'm looking forward to a house where I can make a proper setup.
annunaki
annunaki
Moderator
Ply can make a good straight edge and can be a customizable jig too. I did that for years.
I (finally) got a table saw this year. A quality craftsman unit from the early 90's for just $160(!!) on Craigslist.
It is definitely worth it once you are able.
