Status Acoustics Titus 8T Floorstanding Speaker System Review
Discussion in 'Loudspeakers' started by admin, Dec 10, 2012.
  1. admin Audioholics Robot Staff Member
    admin
    Apr 16, 2004
    172
    1,618
    It isn't often that I review a product that fundamentally changes the way I listen and experience audio. Status Acoustics, the premier line of RBH Sound, has managed to do just that with their new flagship Titus 8T floorstanding loudspeaker system. The sound of this speaker system transcends their physical cabinets, which is grandiose and in your face when called to do so, yet delicate like the petals of a rose beckoning you to carefully listen, rewarding you with pure unadulterated audio perfection. If you're in the market to assemble a cost-no-object audiophile two-channel or multi-channel system, I can't imagine anyone not being completely satisfied with the new Status Acoustics Titus 8T speaker system. These are truly what I consider to be "speakers for life". Highly recommended!
    [​IMG]
    Discuss "Status Acoustics Titus 8T Floorstanding Speaker System Review" here. Read the article.
    • Like Like x 11
  2. monkish54 Audioholic General
    monkish54
    Oct 18, 2011
    1,237
    736
    Los Angeles, CA
    Gene,
    Thanks for the review! :D The speaker is truly gorgeous.
    The huge price tag makes me wonder...why would one (yourself included) want the 8T over the Salon 2 (22,000) or KEF Blade ($30,000)?
  3. Irvrobinson Audioholic Ninja
    Irvrobinson
    Dec 7, 2004
    3,653
    1,420
    For one thing, A LOT more bass capability than either the Revel or the KEF.
  4. monkish54 Audioholic General
    monkish54
    Oct 18, 2011
    1,237
    736
    Los Angeles, CA
    The Revel has the surface area of a 14" woofer, the KEF has the surface area of an 18" woofer, and the Status 8T has the surface are of a 17.4" woofer.
    Add to that the fact that the Revel and KEF's woofers are more than capable of playing VERY loudly with minimal exertion (since there are so many) it's not bass that's going to be gained here. If i added another 27 woofers..but listened at the same volume...I'd still be in the same place (as far as feeling the bass not distortion). The problem with one 8" (Philharmonic) is it has to work VERY hard and therefore SPL is limited. None of the speakers being discussed right now have that issue. They are more than capable of playing VERY loudly, moving LOTS of air, allowing you to seriously feel the bass.
    If anything, the KEF wins in the bass department. 4 9" high power handling woofers. More surface area AND less (probably not a whole lot less...I'm not sure) distortion. :D
  5. Dennis Murphy Audioholic Chief
    Dennis Murphy
    Oct 5, 2007
    995
    1,286
    I haven't heard these speakers, and wouldn't be surprised if they sounded as good as Gene says. But just on a technical note, the article makes a fairly big deal bout the use of Solen Poly Caps in the bass crossover--these are actually about the cheapest high-value poly's you can buy, and are used in many speakers that sell for a tiny fraction of the 8T's asking price. And the 5% tolerance isn't all that tight. That said, I doubt that throwing more money at the bass caps would make any difference in the basic sound.
    • Like Like x 4
  6. monkish54 Audioholic General
    monkish54
    Oct 18, 2011
    1,237
    736
    Los Angeles, CA
    I mean.....
    *RUNS AWAY!*
    :D :D
    • Like Like x 1
  7. gene Audioholics Master Chief Administrator
    gene
    Jul 1, 2002
    8,027
    3,513
    Florida
    The Revel Salon2 is a great speaker but it's not in the same league as the Status 8T. The Revel like most speakers have the same limitation of a conventional 3 or 4-way systems using only 1 midrange driver. After hearing a well executed truncated line array or multiple mid MTM array like the Status system, there is just no comparison in terms of realism and dynamic range IMO. The Status system also has superior bass extension and output. The speaker just sounds lifelike and effortless at any output level.
    I haven't heard the Kef blade so I cannot comment other than when dealing with a truly flagship style tower speaker, surface area for bass and mids really makes a remarkable difference when trying to create the full dynamic spectrum and realism of music.
    gene,
  8. Irvrobinson Audioholic Ninja
    Irvrobinson
    Dec 7, 2004
    3,653
    1,420
    Unlikely with that little dinky-butt cabinet...
  9. Irvrobinson Audioholic Ninja
    Irvrobinson
    Dec 7, 2004
    3,653
    1,420
    The Salon 2 uses two mid-range drivers, because it's a four-way design. But you are correct, there's only one of each.
  10. monkish54 Audioholic General
    monkish54
    Oct 18, 2011
    1,237
    736
    Los Angeles, CA
    The Salon 2 is a four way that utilizes a 1" beryllium tweeter, 4" midrange, 6.5" midbass, 3 8" woofers.
    The Salon 2 is -3db at 23hz :D
    The KEF has more surface are for bass and more bass drivers.
    I can't argue with that! :D
  11. monkish54 Audioholic General
    monkish54
    Oct 18, 2011
    1,237
    736
    Los Angeles, CA
    :eek: :eek: :eek:
    Are we still talking about the Blade? :confused:
  12. gene Audioholics Master Chief Administrator
    gene
    Jul 1, 2002
    8,027
    3,513
    Florida
    you can't just compare surface cone area of bass drivers without knowing driver Xmax and enclosure volume and vent area.
    gene,
    • Like Like x 1
  13. Irvrobinson Audioholic Ninja
    Irvrobinson
    Dec 7, 2004
    3,653
    1,420
    Absolutely. Look at the cabinet volume the RBH has for the woofers. It's like having two medium-sized subs in the system. The Blade seems to have relatively little cabinet volume by comparison.
    • Like Like x 1
  14. Irvrobinson Audioholic Ninja
    Irvrobinson
    Dec 7, 2004
    3,653
    1,420
    That's true. In fact, in-room my pair measures fully flat to 20Hz on my OmniMic. (Well, flat meaning that a 20Hz test tone is delivered at the same output level as an 80Hz test tone. In their current location the bass overall is hindered by room modes, hence I use a sub.) What I was discussing was the output level capability. In his review Gene mentioned extraordinary volume capabilities. The Salons are good, but I don't think they'll do 115db at 20Hz.
    • Like Like x 1
  15. monkish54 Audioholic General
    monkish54
    Oct 18, 2011
    1,237
    736
    Los Angeles, CA
    I don't see exertion being a huge issue with either speaker as they both use so many bass drivers and are both fairly sensitive. You would have to listen ear bleeding levels to make the Salon 2, KEF Blade, or 8T sweat.
    That said here's what I got for the KEF's drivers:
    I will ask Mr. Oclee-Brown what the Xmax is of the bass and midrange drive units. :D
  16. monkish54 Audioholic General
    monkish54
    Oct 18, 2011
    1,237
    736
    Los Angeles, CA
    I thought you were saying the cabinet wasn't very well built. I was like :O.
    The KEF Blade is -3db at 40hz. For a reference product it's an embarrassing extension figure.
  17. GranteedEV Audioholic Ninja
    GranteedEV
    Jul 14, 2009
    4,936
    2,356
    Calgary, Canada
    They're tuned around there, so it would boil down to vent cross section area, not driver excursion. I agree, I don't think the Salon2 vent has the requisite port area to do that without chuffing. The Status definitely seem to have more.
    • Like Like x 1
  18. monkish54 Audioholic General
    monkish54
    Oct 18, 2011
    1,237
    736
    Los Angeles, CA
    That is true. You would need ALOT of power to push them there.
    That is definitely a plus in the 8T category, but is it worth the extra 30K?
    The Blade can push a good 112db at 8ft. The 8T is definitely more dynamic than both, but it is also ALOT more expensive. Is 115db at 20hz worth $20,000 more than 112db at 40hz? :D
  19. gene Audioholics Master Chief Administrator
    gene
    Jul 1, 2002
    8,027
    3,513
    Florida
    Yes a single 4" mid doesn't have near the surface area of four 6.5" mids.
    -3dB at 23Hz at what output level? What is the slope of the rolloff below that?
    What is the Xmax of the KEf bass drivers, what is the box volume?
    Seriously please stick to the topic at hand on this thread which is of the Status speaker system I just reviewed.
    gene,
  20. monkish54 Audioholic General
    monkish54
    Oct 18, 2011
    1,237
    736
    Los Angeles, CA
    No, no it does not! :D
    I will find out. :D
    I personally don't feel comparing two other speakers to the 8T is off-topic considering that is the speaker that was reviewed in this thread, but it is your forum so I will shut up. :D
Share This Page
  • CEDIA
