Hi. What crossover were you running before you swapped to the Sonys? Were you happy with your sub in that case? If so, I'd say consider using that same crossover again. The surround speakers don't get a whole lot of audio (some, for sure, but not the bulk of it), so the amount of audio that you'd lose picking a lower crossover that they can handle wouldn't cause you to lose much from the surrounds - but you might gain back what you liked before.
