Published sensitivity of the 2 speakers is close, (Sony = 89dB, Polk = 88dB), so I don't suppose that is the problem. Perhaps it is your room or relative placement. If you already have the surrounds maxed out, try lowering your L/C/R. See if that will bring them more in line w/ each other. Are you using the same speaker wire to all speakers?
