What Cable Gauge Do I Need for my Speakers?
rotem
I'm using a jbl spyro probably 8ohms and a PC. I need to extend both the cables to right and left and also the cable from the PC to the sub.
markw
I'm building an experiment with a 20kHz signal and I need the best cable with the least attenuation for around 50m or more. I couldn't find from the spec of some cable what is the attenuation per feet for a cretin frequency.
thanks
rotem
And you want to extend that 50 meters? Dude, you need more than simple cables if you don't want signal loss at the far end, much less at the high end. Start thinking amplification.
Can those speakers even do 20 khz?
rotem
They can. and I can handle signal loss as long as I can predict it before.
Speedskater
Speedskater
At a length of 50 meters and a frequency of 20 kHz, cable self-inductance becomes more of an issue than cable resistance. What might work is if you can find a roll of Cat3 or Cat5 cable. You could parallel several cables. Connect all the solid colors to one terminal and the stripes to the other.
Rickster71
Rickster71
Isn't the volume control on one of the speakers? So you'll have to extend that wire too.
How's that going to work, using the control 50m away?
Speedskater
Speedskater
Wait a minute! The JBL Spyro is a very, very tiny POWERED desk top speaker system. I'm not sure how it works/connected. Are you just going to cut the wires?
markw
Well, duh!
You just realized this? As such, it's working off a signal designed to drive headphones, or self-powered computer speakers. IOW, little more than line-level.
markw
Are you sure?
If these specs are what you're basing your experiment on, I'd rethink your plans. "Real" speaker specs include a decibel variation when they state a frequency range: (i.e: 40 -15 khz +/- 3 db) For all we know, they could be 15 decibels down from 1khz.
rotem
I'm not basing it on a spec. I've checked it. I'm trying to extend without cutting the speaker wire, with RCA connectors. I was thinking about a regular extender, power cable. with RCA at it's ends and I will check the attenuation. I'm not sure how to extend the volume wire. I'm planing to test it mono to start with.
markw
You do realize that you're obsessing over what grit polish to use on a turd, don't you?
Z
Zene
Hi ... does the "Speaker Cable Gauge ... Recommendations" article apply to active tri and quad amped systems as well.
Seems as if the power and higher frequencies would figure into the sizes.
Thanks, Zene
Irvrobinson
Irvrobinson
Thanks, Zene
My advice is, don't over-think this. Use 12ga or 10ga for every connection. Ignore marketing nonsense about skin effect or whatever affecting high frequencies.
Z
Zene
irv ... Thanks for your input. but that's as much misconception as a mfg. I'm not about to just grab some cable and fly with it because everyone else does it. Been at the game too long not to delve into
what is really going on with the little electron buggers. For a tweeter 12 gauge makes little sense if it's crossed at a point where the impedance is quite high. The lower the cable resistance following is certainly not the answer. No offence to you personally. Zene
Irvrobinson
Irvrobinson
Zene, you're lost. Have you read any of the cable articles on this site, under the AV Research tab? They're quite excellent.
gene
gene
Audioholics Master Chief
Administrator
Cable resistance is the single most important metric with speaker cables at audio frequencies. Everything else is secondary.
Z
Zene
Irv ...reading like crazy and finding no scientific evidence other than personal speculation. Not good enough.
Gene .. Are you saying the lower the better? If so, I find that hard to believe, also.
Thanks guys, Zene
Irvrobinson
Irvrobinson
Thanks guys, Zene
Zene, what the heck are you reading? Did you read any of the articles on this site? Properly designed speaker cables exceeding the minimum AWG for distance and load impedance do not materially affect frequency response or distortion. I don't know what you're reading, but that's not opinion, it's measured fact. You're sounding like a person who either has an agenda, or has already drawn a conclusion without any knowledge.
jcl
Roger Russell of McIntosh fame has an informative web page on speaker wire.
gene
gene
Administrator
Thanks guys, Zene
Yes and the article I wrote about this clearly shows that:
Speaker Cable Gauge (AWG) Guidelines & Recommendations | Audioholics
High resistance has a much more profound effect on performance than capacitance or inductance for speaker cables, especially when dealing with low impedance speakers.
