I have a Creative X-Fi Titanium HD soundcard and I have run an optical toslink to an AVR (Anthem MRX500). I want to bypass the soundcard DAC sound that I don't end up with a DA / AD / DA scenario. I am running a 2.1 speaker configuration from the AVR.
I have set windows (8) to use SPDIF by default.
I have first tried running Foobar Output as DS SPDIF (Creative). I get some crashes and some bad pops and other nasties when playing files.
So, I thought I should try WASAPI. When I set Ouput to WASAPI SPDIF (Creative) I get the following playback error: Unrecoverable playback error: Unsupported stream format: 44100 Hz / 24-bit / 6 channels
The AVR and card support 24 bit (which I have set in the Foobar Output options) but I've also had the same error if I set it to 16 bit.
I get this on lots of channels. I'm puzzled (even more so at the 6 channel reference!). Can anyone help please?
EDIT: I'm also having crashes with VLC too - a movie will play fine for a while and then if I pause and restart, every now and again the picture will freeze. Something is definitely not right but I can't put my finger on it.
