I've been into headphones for about 25 years. I can vouch for the view that in the headphone world, sources, cables, and amps are massively over-rated. Unless you are into it and completely fascinated by it beyond rationality (as I am), standard inexpensive but decent receivers, cables, and sources will take you to the top of the mountain sonically very quickly, assuming you are not interested in sound-shaping capabilities beyond searching for a headphone you like a lot.
My two biggest thrills as a headphone enthusiast have been in the last several months, from the pro-audio world, with the Behringer DEQ2496 digital equalizer ($300) and the Behringer UB802 mixer ($60). The DEQ2496 gives you tremendous sound-shaping capabilities (parametric and graphic EQ, dynamic compression and and expansion, image compression and expansion, noise gate, real time analyzer with mic input, etc. etc. etc.) and the UB802 gives you tremendous amplifying capabilities (high performance and features including panning controls to merge or reverse channels, three way tone controls, 4 inputs, etc., in a relatively small and light housing, at a low low price). The DEQ2496 is just a thrilling and fascinating piece of gear, destined for the status of legendary audio equipment, IMHO.
http://www.behringer.com/DEQ2496/index.cfm?lang=ENG
http://www.behringer.com/UB802/index.cfm?lang=ENG
Downside to the UB802: no on-off switch (I use a power strip).
I also have a Corda HA-1 headphone amp. There's absolutely nothing wrong with it, and the noise floor is extremely low, and you get a theoretically ideal near-0 ohm jack and an industry-standard 120 ohm jack. And the volume knob is wonderful, a nice, big, finely adjustable knob. Three levels of crossfeed if you want to try that. Seemingly unsusceptible to ground loop noise. Very well done. A nice piece of jewelry, and I'm glad to have it. IMHO, anything in an amp performing at a level above the HA-1 would be a complete and utter waste of money. In fact, you could pay a lot less (e.*., UB802) and loose nothing in terms of audible performance. But it's a pretty good no-nonsense effort at DIY hyper-performance, IMHO.
But the DEQ2496 and the UB802 COMBINED cost about the same as the HA-1. If I had to do it over again, I'd skip the HA-1. Fortunately I bought the HA-1 first so I don't have to choose.
