I have an in-law suite that my Mother in-law will be moving into sooner than later. the suites living room is below my master bed room and is also next to a room that we use as our main tv room. I really want to decrease as much noise as i can from either side. I have gutted the in-law suite down to the studs and beams and now need to figure out what will work without breaking the bank. multi layered drywall with that green glue between is over $50 for a 4x8' sheet. The room is 11.5' wide by 20' long. Are there any DIY ways to soundproof the room without killing my wallet? I was thinking about installing a medium density fill between the beams in the ceiling and just using an R-15 insulation in the walls to insulate/dampen the sound. I was also thinking about lining the studs and beams with the Styrofoam sheets that are normally used to insulate a concrete pad from a wooden stud (normally used to prevent moisture is the concrete from damaging the studs). I thought this may isolate the drywall from the studs and help lower noises being passed through? any help would be greatly appreciated. Thanks Chuck
