Sony Vpl-VW100 LAMP REPLACEMENT HELP
Discussion in 'Televisions & Displays' started by ficus, Jun 6, 2007.
  1. ficus Audiophyte
    ficus
    Jun 6, 2007
    1
    0
    Hi,
    My lamp recently ran out on my projector. I bought a new one direct from sony and have fitted it. But the problem i am having is that once you replace the lamp, there is a code to reset the lamp timer. I have entered it but am still the onscreen message telling me to replace the lamp.
    any ideas anyone?
  2. mtrycrafts Audioholic Slumlord
    Aug 19, 2004
    16,054
    1,354
    Is this after properly seating the new lamp and inserting it?
    Have you called Sony? May need to call their service center in Laredo I think.
    You may also try to ask at AVS on the over $3k projectors. There are a few who have replaced their bulbs in it.
  3. mtrycrafts Audioholic Slumlord
    Aug 19, 2004
    16,054
    1,354
    By the way, how do you like your projector? How large is your screen? Do you have hi def yet?
  4. jfatal Audiophyte
    jfatal
    Sep 17, 2007
    1
    0
    reset lamp timer
    You can reset the lamp timer by entering on the remote control the following:
    RESET, <, >, ENTER
    This must be done in standby mode (red light indicator).
    Good Luck...
  5. sbecker Audiophyte
    sbecker
    May 31, 2010
    1
    0
    Same problem, but solution not working
    I'm having the same problem as ficus, but powering the unit down didn't solve it for me. If anyone has any ideas, I'd be grateful.
    Thank you
  6. jostenmeat Audioholic Spartan
    jostenmeat
    Feb 26, 2007
    6,789
    3,052
    I was unsuccessful at first with my own JVC, because I was being deliberate, and not fast. The key with JVC is to do it VERY quickly (like both thumbs).
    I have no idea if that may help, but it's the best I can offer right now, assuming the above code is a good one.
  7. Kerby Audiophyte
    Kerby
    Jul 13, 2010
    1
    0
    Tulsa, OK
    Resetting the Sony VPL-VW100 Hours
    The problem is that the instruction on page 65 of the manual (at Sony's website) are misleading. After the manual walks through the lamp and filter replacement, the instructions state (with the projection in standby mode - meaning off but with power): "Pointing the remote control at the projector, press the following buttons on the remote control in the following order for less than five seconds each: RESET, <-, ->, ENTER. The problem is that these instruction should not include the word "each" and it should be said that all four buttons are to be pushed quickly (meaning you need to push each button - in order - as quickly as possible.)
    Sony's customer support is not aware of this simple error and do not be mislead by other posts that state that the buttons are to be pushed simultaneously. This is not correct.
    In short, push RESET, <-, ->, ENTER (in order) but very QUICKLY.
Share This Page
  • CEDIA
