He is another Budget AVR for you consideration.. what do you think of it Do you already have one?
MSRP.
Price: $498.00
Product Description
Stream crisp, powerful audio with built-in Wi-Fi, Bluetooth and Airplay. With 7.2 channels and 150 watts of power, it's legendary Sony sound that really connects. Featuring 4k resolution pass-through, high-res audio compatibility, 6 HD inputs and a new intuitive graphical interface, this receiver brings out the best in your music, Blu-ray movies, games and more.
From the Manufacturer
7.2 Ch 4K Wi-Fi Network A/V Receiver
Stream crisp, powerful audio with built-in Wi-Fi, Bluetooth and Airplay. With 7.2 channels and 150 watts of power, it’s legendary Sony sound that really connects. Featuring 4k resolution pass-through, high-res audio compatibility, 6 HD inputs and a new intuitive graphical interface, this receiver brings out the best in your music, Blu-ray movies, games and more.
Technology
The heart of your system.
Stream crisp, powerful audio with built-in Wi-Fi, Bluetooth and Airplay. With 7.2 channels and 150 watts of power, it’s legendary Sony sound that really connects. Featuring 4K resolution pass-through, high-res audio compatibility, 6 HD inputs and a new intuitive graphical interface, this receiver brings out the best in your music, Blu-ray movies, games and more.
Built for sound.
Borrowing construction and circuitry design cues from our ES line, it all begins with a rigid chassis based on the legendary frame and beam concept. To this structure, we then mount the various components: a high capacity power transformer, custom heat sink, and other specially selected audio-grade components that together add up to class-leading sound quality. For purists, Pure Direct mode preserves signal clarity and detail by switching off unnecessary signal processing circuitry to provide the cleanest possible signal path with minimized electronic interference.
Sweet Sound.
Not only powerful, to deliver impressive multi-channel sound performance. (145W x 7 @ 6 ohms, 1 kHz, 0.9% THD), the STR-DN850 features the best audio technology from both Sony Music and Sony Pictures and can even support Hi-Resolution audio playback (bit rates up to 192k/24-bit WAV/FLAC). Added amplifier functionality allows for configuration flexibility including: speakers A or B, speakers A and B, in addition to Bi-Amp should the scenario call for it.
Wi-Fi Built-in1
Wirelessly connect to your home network and via the integrated DLNA support access music stored on: your computer, network storage device, or even your smartphone. Via built-in music service support13, you can access and enjoy music streaming at its very best-the latest from Pandora, Spotify, Music Unlimited, and tunein. Also AirPlay compatible, you can easily stream your music and music apps from your iPhone/iPod/ iPad or iTunes.
Connect it all with Bluetooth1
The STR-DN850 receiver effortlessly streams music from your smartphone or tablet so nothing is out of reach. Now anyone can be the DJ-no wires, no problem. Bluetooth streaming can even wake the receiver from standby mode to get the party started. Built-in AAC and aptX codec support avoids signal quality loss when streaming music wirelessly.
Well Connected.
Enjoy versatile HD connectivity with five HDMI inputs (up to 4K capable) and connect a Sony PlayStation entertainment system, Blu-ray Disc player, or any other HDMI-capable devices2. Via an MHL (Mobile High-Definition Link) certified HDMI cable, you can even plug-in your smartphone and share favorite personal video clips, music, and more on the big screen complete with big sound3. The front-mounted USB input even allows for easy connectivity and charging with compatible devices1.
Additional Features
Advanced On-Screen Display.
Class-leading performance demands a powerful user experience. Via an advanced on-screen user interface, the STR-DN850 affords comprehensive system control, settings adjustment, input selection, and the like with seamless visual confirmation on your TV screen.
HD Digital Cinema Sound.
Optimize receiver settings to mimic movie theater sound characteristics. Front Height mode enables vocal height and 3D effects for improved effects positioning and added depth. Imagine as a helicopter descends from above and lands right in front of you – you’ll hear the change in height as the effect unfolds on-screen.
Easy Setup, Optimized Use...
Proper system setup and optimization shouldn’t be an ordeal. Easy Setup using the simplified remote in comjunction with an intuitive, on-screen interface, leverages the power of Digital Cinema Auto Calibration (D.C.A.C.) and a supplied microphone to optimize settings based upon room charachteristics and speaker distance and placement.
Handy Remote Control.
Easily and intuitively control the receiver via SongPal and your Bluetooth-enabled smartphone. Simply download the free SongPal app from iTunes or Google Play Store, install it on your smart device and take control of your receiver and your favorite movie and music content, including receiver settings, media metadata, and more – all through one app.
1Wireless connectivity requires an 802.11 home network (802.11n recommended).
2Broadband speed of at least 2.5 Mbps recommended (10 Mbps for HD). Content subject to change and may require fees.
3Interoperability and compatibility among Bluetooth devices vary.
4Requires HDMI cable sold separately.
5Cable sold separately.
64k upscaling requires a 4K projector or 4K TV.
7Requires capable HDTV, capable video source, and HDMI cable sold sep. When playing copyright protected content from Sony 4K server, it is necessary to use a separate HDMI audio out from server to receiver for surround sound support.
8Application must be downloaded from the iTunes application store or Google Play store. Requires devices connected to the same wireless home network. Subject to app terms and conditions.
9Requires HDTV and HDMI cable sold separately.
10Not all USB devices are compatible. Consult
www.esupport.sony.com for complete details.
11Requires 3D content, 3D HDTV, 3D glasses and HDMI cable (at least 10.2 Gbps).
12Requires HDMI cable sold separately.
13Requires HDMI cable and LPCM capable receiver.
14Syncs with BRAVIA Sync or Theatre Sync products.
15Requires content stored on a DLNA compliant PC or server.
