I have read some conflicting views on this matter and am now unsure as to what is best for me to do. My two Infinity Qe speakers have been aimed straight (Parallel with the wall) for the longest time, however my room is tiny (8'x8'x10') and I was reading somewhere that they recommend toeing the front speakers in slightly and somewhat aiming them at my head so that each one is not perfectly flat with the wall, but turned towards me. Someone else had told me this destroys the imaging effect where the thing that told me to do this results in better imaging. Erm, so which is it? In a sense I can see why it would be bad for imaging since the sounds are not eminating straight out (as if to implicate the sound is eminating from the TV), but in another I can see why them being aimed at you so that with certainty both speaker's sound fields are hitting you would provide better imaging. Definitely would like to know which is true so I know if I should have the speakers parallel with the wall or toed in!
As nibhaz has already pointed out, you'll need to experiment. Otherwise, I've read that having the axes of the speakers cross just in front of your face is a good starting point. Also, perhaps an equilateral triangle between the speakers and you. Still, there are always compromises. Certain sites will say that imaging cohesion will falter if the angle greatly exceeds 30 degrees. Then, OTOH, some of the best imaging I've ever heard were with angles considerably greater than 30 degrees. It'll depend on the speakers themselves, the room itself, and where you and your speakers sit in it. Oh yeah, that whole personal preference thing too.
How the hell does putting the speakers BESIDE you result in a surround effect? They're so close to you that it would make me think the sound is coming from the left or right channels respectively. My computer speakers are setup in the latter way with them behind me and do the role of surround great - the short time I had to put my surround speaker beside me and slightly to the rear it sounded like rubbish. Why do people recommend this, it's the most awful setup I have heard! Every good sounding surround system I've heard that is 5.1 is with the surrounds BEHIND the listener. I was under the impression that 7.1 was basically adding the side speakers, not the rear. Anyone care to enlighten me on why this is supposed to be the ideal setup?
The problem was super close proximity, most likely. When people put speakers at a 110 angle, they are trying to straddle both the side and rear areas. When you have a 7.1 setup, you have more flexibility in using 90 degrees for the sides, and I personally believe that is the ideal. The further back your sides are, the greater the "hole" is, so to speak, between them and your fronts. This becomes even more evident/extreme if your mains are close together, or represent a small angle. Panning effects sort of jump from one distant spot behind you, to another in front of you, rather than being as seamless as can be. I have holes too, but we all have compromises. I don't feel like using redundant side surrounds for my multirow theater.
Also, I'm beginning to notice that where I previously thought a dipole speaker would be the thing to use in my room I am starting to see that since I am the single and sole listener to everything in my room direct radiating rear speakers are probably the most ideal speaker type to use with my system since they will always be positioned ideally to my listening position. I know they say that the rear speakers aren't drastically important since they're mostly just effects and ambience, but given I am using this with THX doesn't THX provide full range to the rear speakers meaning that much more sound will be sent to the rear channels? I have always been told that when using THX that you could (If given the room and money) use floorstanding speakers as rear channels due to the fact they will receive full range from the movie.
Yet again, personal preference plays the greatest role in using dipoles. Otherwise, they are not superior for surround duties, or at least haven't been for a long while. All of the surround ambient cues are already embedded for you in the audio tracks.
Thanks again for both posts, very helpful - and I hadn't seen that last link you posted previously when I was searching on here for that info. Now if only I can find some bookshelf speakers locally - been looking for awhile and haven't had any luck yet!
I agree that nibhaz has been extremely helpful to you.
