Ok, first time poster, but long time lurker... Just want to give back to the DIY community after you guys have helped me create really good cables, speakers, enclosures, etc.
First off:
I know a guy who is selling 100metres (330ft) of high-quality UTP Cat5E plenum cables with teflon insulation. I ordered from the guy, and I got it pre-cut in the sizes I wanted (i asked for 20% longer lengths than what I was shooting for. I think 10% longer would have been better.)
Basically, it's 328feet of cable for $30, (I think he charges $20 for 164feet (50m)). It's 24AWG solid bare copper conductor, 4 Pairs, Teflon insulation, and plenum jacket. Standard high-quality ethernet cable. Let me know if anyone is looking to get this stuff. I was too excited after building these cables, and was trying to convince myself of things I wanted to believe, I guess. :-/
Ok, about the findings:
Doing my own measurements, I found that I could keep the capacitance lower by doing a flat braid using the 6 wires, and keeping the plenum jacket on. The resistance and inductance were not affected noticeably. (The capacitance was greatly increased with the jacket off, though. And of course, the more cables, the higher the capacitance, and the lower the resistance.) In a blind test, I couldn't tell the difference between these cables and any of the other cables at the audio store(Kimbers, ACs, AQs, etc), but there was a noticeable difference between these cables and ones like SoundKing, Monster which were 16awg or higher. I think the thicker cables generated a cleaner sound.
So what does this all mean? Well, according to my ears, ,and those of the manager at the audioshop, we came to the conclusion that the cheap cat5 cables really do sound the same as the more expensive cables. I found it funny how the manager would not believe that it cost me around $40 to make the cables that would rival cables at 5x the cost and more.
So, if anyone is new to the cat5 cables, I would recommend that you keep that jacket on, put on a sleeve or heatshrink, and save yourself the hassle of imperceptable differences in sound. The braid pattern is probably more important, but then again you probably won't notice any difference.
Anyways, thanks so much for all the help, and I hope this will benefit someone who's looking into making some cat5s.
EDIT: Ok, you're right. There was a difference because the sales guy had connected the cables to different drivers. Went back, and grabbed 15 diff. brands of cables, did the test again with exact same setup. I could not tell the difference between any of the cables, save the skinny ones. And now, I think I'm imagining that too. Oh well. $30 to get all my cables made is not, and they look pretty cool too.
