I just sold my Onkyo SC-885 and picked up the AV 7005 today. I have set up many AVR's and Pre Pro's and this seemed very simple to set up. I connected my Oppo 983, PS3, Direct TV box, and HTPC, all via HDMI. Once I set up the inputs in the setup menu I got strange results.
My Direct TV works as it should-- audio and video via hdmi is fine. However, my Oppo passes audio but no video gets to the set. I changed cables, and switched inputs to see if the problem was in the input on the 7005-- but direct tv worked fine in all hdmi inputs. When I connect the Oppo directly to my set, it does not show video via hdmi, but does via component. I did not change any settings on the Oppo while it was connected to the 885 and it worked perfectly. My set is 6 years old (Sony) and does not support 1080p so I have the resolution set to 720p on the Oppo.
I know I must be missing something fairly simple in the setup menu of either/both the 7005 or Oppo 983, but I have spent half the night trying to trouble shoot this issue and I am at my wits end. I can hear movies and cd's, but cant see the display on the screen. I have double checked that connections are snug and correct. Please help!!!
