Setting up Tower speakers and sub
Discussion in 'Loudspeakers' started by LOA5000, Dec 7, 2012.
  1. LOA5000 Audioholic Intern
    LOA5000
    Sep 22, 2012
    45
    1
    Hello i got 2 Sony f7000 speakers in the front with a sony center speaker. 2 Sony f6000 speakers as sourrounds and 2 Sony F7000 speakers as the rear sourrounds. And we have a bic v1220. The Receiver is a sony STRDN1030.
    I did the auto calibration and after that i changed the speakers from large to small. Should i lower the frequency of the tower speakers from 80 to 60? and what should i set the sub at should i set it at highter then 80?. If i go from 80 to 60 with the towers can keep the sub at 80 or does that have to be dropped down to do 60 and below? Thanks!
    What i would like is lots of rumble but also i dont want to lose any sound quality by going to low. And the question is there a big difrence from 80 and 60 for the towers?
    The center speaker is rated 85 - 50000 Hz. Should i set that at 80? 85? 100?
    Sony STRDN1030
    Amazon.com: Sony SSF-7000 Floor-Standing 4-way Speaker with 8" Woofer (Pair): Electronics
    http://http://www.amazon.com/Sony-SS-F6000-Floorstanding-4-Way-Speakers/dp/B000OG4E20/ref=sr_1_1?s=electronics&ie=UTF8&qid=1354927333&sr=1-1&keywords=sony+f6000
    Amazon.com: BIC America V-1220 12-Inch 430-Watt Down-Firing Powered Subwoofer: Electronics
    Amazon.com: Sony SS-CN550H Center-Channel Speaker (Single Speaker): Electronics Center speaker
  2. zieglj01 Audioholic Spartan
    zieglj01
    Aug 30, 2010
    5,249
    1,605
    Texas
    Is this a room, where one is sitting 20 feet back from the TV?
    • Like Like x 1
  3. LOA5000 Audioholic Intern
    LOA5000
    Sep 22, 2012
    45
    1
    Hello
    yeah it is.
  4. zieglj01 Audioholic Spartan
    zieglj01
    Aug 30, 2010
    5,249
    1,605
    Texas
    Well, you are not going to get much rumble out of that subwoofer.
    I would at least, find a way to buy a second one.
    However, set the crossovers for now >
    Center 100 hz
    All other speakers 80 hz
    Subwoofer, turn the crossover all the way up.
    • Like Like x 2
  5. LOA5000 Audioholic Intern
    LOA5000
    Sep 22, 2012
    45
    1
    Okay question. The bic v1220 and f12 seem to be a close sub. the specs seem close. Should i buy the f12 or anther v1220?
    BIC America 12" 430Watt Powered Subwoofer V1220 - Best Buy
    Amazon.com: BIC America F12 12-Inch 475-Watt Front Firing Powered Subwoofer: Electronics
  6. zieglj01 Audioholic Spartan
    zieglj01
    Aug 30, 2010
    5,249
    1,605
    Texas
    • Like Like x 1
  7. LOA5000 Audioholic Intern
    LOA5000
    Sep 22, 2012
    45
    1
    thanks
    You think adding anther sub would be better? I know the Sony towers have a dedicated 8inch woofer for lower bass and anther dedicated 8 for mid range on each tower. You think I should lower them down to 60 cross over. Or you think put them at 80 and have 2 subs would be much better? Also by setting them to 80
    Does it still take advantage of the 4 way speaker concept
    Or by setting them to 80 just like having a book shelf speaker
    Thanks again for taking the time to help
    PS I was also reading where people say for the v1220 to set it at 60 cuz it doesn't do well above that or something
    Could I get something better then 2 bics for 400 dollars? How much better is the bic pl200
  8. zieglj01 Audioholic Spartan
    zieglj01
    Aug 30, 2010
    5,249
    1,605
    Texas
    I would do the settings as I posted earlier -
    Now if it were me, I would buy this Cadence 12 inch subwoofer,
    it is around 122 db at 50 hz > and 105 db at 25 hz. And Then I
    would sell your other BIC sub, and buy another Cadence sub.
    CSX12 Mark II - Cadence Sound Store
  9. LOA5000 Audioholic Intern
    LOA5000
    Sep 22, 2012
    45
    1
    They also have a 15inch model what you think of that?
    Where is the port
  10. zieglj01 Audioholic Spartan
    zieglj01
    Aug 30, 2010
    5,249
    1,605
    Texas
    I favor the 12 inch one - the measurements look better to me,
    over the 15 inch one
    The slot port is on the front
  11. LOA5000 Audioholic Intern
    LOA5000
    Sep 22, 2012
    45
    1
  12. zieglj01 Audioholic Spartan
    zieglj01
    Aug 30, 2010
    5,249
    1,605
    Texas
  13. LOA5000 Audioholic Intern
    LOA5000
    Sep 22, 2012
    45
    1
    You think there is a difrence between the Sony older center speaker cn550h and the cn5000
    Will they work the same? The specs seem to be the same
  14. zieglj01 Audioholic Spartan
    zieglj01
    Aug 30, 2010
    5,249
    1,605
    Texas
    I think That I would upgrade to a whole new system - go back to your
    other thread.:)
Share This Page
  • CEDIA
