I have a very complex issue that I need some expert advice on. I want to say that up to this point my current system has been running fine, but I am trying to clean it up a bit to prepare for adding a new TV.
Currently I have a computer that has a 3.5 mm headphone jack and I have a 3.5 mm y cable splitting the signal to two separate Belkin Audio Y Cable Splitters that go from 3.5 mm to RCA. One of these goes to my Onkyo TX-SR504 and the other goes to my Sharp SA-R75AV. The Onkyo runs the speakers and the Sharp runs my old Infinity Car Audio Subs in a custom box with the correct watts and Ohms. The Sharp puts out 8 Ohms, and my subs are each wired in Series to create an 8 Ohm load per sub, so I have a right sub and left sub.
When I play the radio, I use both AV Receivers in FM Mode. When I play Pandora off my computer I use both AV Receivers in CD mode. Finally I have a TV hooked up off the headphone jack with another y cable 2 more Belkin Y adapters from 3.5 mm to RCA cables and I use the Receivers in Video/VCR mode.
All that said I have 2 3.5 mm Y cables and 4 3.5 mm to RCA cables just to make it work right now.
I got a new TV and it doesn't have a 3.5 mm output, instead it only has optical out which leads to my problem/issue.
Can I hook up the optical out to my Onkyo Receiver and then use the Sub woofer Pre Out and another RCA Y-cable to send the signal to my Sharp Receiver which will drive the subs? Technically speaking wouldn't this be the exact same as a powered sub? If this works, can I also get rid of all my other cables and run everything strictly to the Onkyo with only the Sub Woofer Pre Out RCA cable to the Sharp for when I play the Radio or CD(computer) Player.
I think this will work, I just can't find any specifications if the signal from the Onkyo to the Sharp will only be 20-200hz or if there is a way to know. Or if the output signal from the Onkyo to the Sharp will be less requiring me to turn up my subs higher than I currently do now.
