I have an unfinished basement space, concrete floor and (mostly) cinderblock walls, about 18’ x 20’ that I want to turn into a serious two-channel audio room with HT potential. I will have to go somewhat slowly with the finishing, but it seems I should go in this sequence:
• Soundproof between ceiling joists to block sound from room above
• Install electrical in joist space under/between soundproofing, with at least two 20A circuits (one for audio, one for bench/workspace/second stereo) with normal height outlets
• Create wall to separate from rest of basement (open space is more like 18’ x 36’)
• Panel cinderblock walls and other walls with rigid fiberglass.
• Carpet floor, and maybe use vinyl damping sheets under carpet. Or build floating floor – but lose more height!
ALL SUGGESTIONS WELCOMED!
I’m looking specifically for advice on #1. I figure first worry about blocking sound, then use rigid fiberglass + foam to absorb. So on the blocking part, I’ve got the 16” spaced joists. How about I get ½” or 5/8” drywall, cut in 8’ strips to fit between joists, apply 3 or 6 lbs/square foot vinyl sheet on top, then nail into underside of flooring? If that’s reasonable, do I cut to leave ½” vinyl sheet on each side of the drywall, so that when I push it into place, the vinyl “seals” or isolates the drywall from the joists? Also, there are hundreds of nails sticking down from the flooring. So what if I use some kind of filler/spacer to avoid having to cope with all the nails, such as the rigid fiberglass instead of the vinyl?
Then if I want to go really crazy, I do a second layer of drywall plus the vinyl. I could use the resilient channel tricks to isolate from the joists, while adding a little air space between drywall layers. Or should I spend the extra attention on the naked joists instead?
Thanks for any pointers!
--tubino
